ECU wire protector cover...worth $25?
Discussion in 'Prius v Accessories and Modifications' started by Mike500, Nov 7, 2013.
  1. Mike500
    Mike500 Senior Member
    2,593
    767
    I just ordered this ECU connector cover on eBay.
    I know that it a small piece of plastic, but it does protect the thin 20 or 22 gauge control wires from damage.
    To me, I think it is worth it. I've NEVER had mouse damage, but I thing it's worth having. Replacing the connector and wires would be very expensive.
    51,787
    that's cool, where is it, under the bonnet?
  3. Mike500
    2,593
    767
    Yes!
  4. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    It's the ecu module right next to the fuse box in the engine compartment. ;)
    Rude person's, does this mean there will be a version of this cover machined out of billet aluminum or some other high quality material in the future? :D
    SCH-I535
  5. Air_Boss
    Air_Boss Senior Member
    4,183
    1,175
    New Yawk
    Always wondered why those fragile wires were exposed and unshielded.
  6. Mike500
    2,593
    767
    I'm see when I get the one I ordered.
  7. Kurt E Sanders
    Kurt E Sanders Junior Member
    36
    Xenia, Ohio
    2013 Prius v wagon
    Just ordered.. Great idea to save a possible headache later
    Mike500 likes this.
  8. tanasit
    tanasit Member
    399
    60
    Philadelphia
    There it is.
    Below are a few more covers:
    Mike500 likes this.
  9. RRxing
    RRxing Senior Member
    2,542
    1,817
    NEPA
    Looks great, but does anyone know the real reason that Toyota left it exposed in the first place? Please don't tell me it was to shave off a tenth of an ounce off of the weight...
  10. Mike500
    2,593
    767
    Money! Millions of cars and the few seconds to put it on as well.
    Regulations in other countries might require the cover, but not here in the US.
    The British MOT inspection is tougher than here in the US.
  11. tanasit
    tanasit Member
    399
    60
    Philadelphia
    How about to shave off some $$$?
    I believe the whole set cost about $400.00 :(
    Mike500 likes this.
  12. Air_Boss
    4,183
    1,175
    New Yawk
    Cost (installed) to Toyota might be a few percent of that...
  13. RRxing
    2,542
    1,817
    NEPA
    I was referring specifically to the one covering the ECU...
  14. tanasit
    tanasit Member
    399
    60
    Philadelphia
    I do realize that but some sellers offer as the set which includes the power inverter cover, coolant reservoir cover and the connector you mentioned. When I first purchased just the inverter cover, it was $135!
    Now the ECU connector cover is about $25.
  15. RRxing
    2,542
    1,817
    NEPA
    I would be leery of putting a cover over the inverter. The metal casing dissipates heat, the sworn enemy of electronics.
  16. tanasit
    tanasit Member
    399
    60
    Philadelphia
    The inverter cover is standard for many other countries and the plastic engine cover is standard for ALL, no over heat issue reported!
  17. Mike500
    2,593
    767
    Got my cover, today. It came by registered mail.
    It is a highly engineered piece of plastic with two very small "micro" snap on ears.
    Expensive, but I'm happy. It is WORTH the $25 to me.
  18. thx123
    thx123 Junior Member
    CA, USA
    2014 Prius Plug-in
    Did you have to pull the grey lever to install the cover?
  19. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Aussie ones uncovered as well.
  20. reloucks
    reloucks Junior Member
    Colorado Springs
    2014 Prius v wagon
    Has anyone researched to see if this or the covers for the inverter are available here in the US either from Toyota or Lexus. I am a recent owner of a 2014 v and was surprised to see that under the hood that this was missing along with any kind of cover for the inverter. My 07 had covers so what gives?
