Air Conditioner Problem
Discussion in 'Gen 3 Prius Main Forum' started by calirider, Nov 13, 2013.
  1. calirider
    calirider ECOmobile
    105
    33
    California Central Valley
    This morning my AC only blows cold and at my feet.
    What is the deal? Anyone else ever have this happen?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    A little more info just may be in order if you want anyone to assist you here. What are the conditions, the climate control system settings, etc.?
  3. calirider
    calirider ECOmobile
    105
    33
    If I put the temp to HI and move the arrow to anywhere defrost upper vents anything it just stays on the feet and blows cold.
  4. jdcollins5
    5,131
    1,346
    Wilmington, NC
    And if not on Hi what does it do?
  5. calirider
    calirider ECOmobile
    105
    33
    It always blows cold and at the feet.
  6. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Even in Auto with moderate temperature setting? If so it sounds like you have a problem with the climate control system or the damper actuator.
  7. calirider
    calirider ECOmobile
    105
    33
    No matter what setting, no matter what temp, no mater auto or not auto, no mater what mode, no mater if the AC is on or off, no mater defrost or not defrost, or any other combination possible.
    It stays cold and at my feet.
  8. jdcollins5
    5,131
    1,346
    Wilmington, NC
    It sounds like you have a defective climate control system. If you are within warranty take it to your dealer and have it repaired or replaced. If out of warranty, well, it probably still needs to go to the dealer for diagnosing.
  9. calirider
    calirider ECOmobile
    105
    33
    Thanks for responding. I was hoping someone would know what was wrong and I could do a cheap fix. Oh well, it's only money, haha. I'm 7,000 miles out of the 36,000 warranty.
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    Cry on there sholder a little bit, maybe they will get a hold of Toyota and maybe they will help out with a little bit of help on costs. Never hurts to ask, sometimes it works.
  11. BZzap!
    BZzap! Senior Member
    1,607
    878
    Sounds like the air door actuator motor might be the problem. It could also be the control head not supplying the signal to the motor. In any event it looks like a trip to the dealer. In which case I would start to talk to the service manager for some kind of policy adjustment from the factory.
  12. macman408
    1,179
    368
    I'd guess maybe a loose or broken cable somewhere, or possibly a problem with the A/C Amplifier ECU. According to the repair manual, it looks like there's a single connector that controls the outlet dampers, the air mix damper (i.e. hot/cold), and the inlet damper (fresh/recirculate). It also carries the signal giving the temperature of the A/C evaporator.
    It looks like you can check for a DTC on the A/C panel - try this at your own risk, I have no idea what it might do... It looks like you need to turn the car off, then go to ACC mode for >5 seconds, then go to IG-ON while pressing both Auto and Recirculate on the A/C panel. It will flash all the indicators on the A/C panel four times, and will then display any DTCs it has stored - if it shows 00, then it hasn't detected any trouble. The manual's writing is not clear, but it seems like it should cycle through them automatically if there is more than 1; you can also press Mode to cycle through them manually. Press Off to get out of the diagnostic mode.
    If it were the cable or connector, I would guess you might see DTCs 13, 41, 42, 43, and/or 97 displayed. Those are for the evaporator temperature sensor, air mix damper control, air inlet damper control, air outlet damper control, and Bus IC communication malfunction, respectively.
    It looks like this ECU is in front of the console box, that open space under the flying bridge, where the power socket and heated seat buttons are housed. So if you're adventurous, you might be able to find the ECU and check the connections. I'm not sure if the connectors are labeled, but it would be an 8-pin connector (2 tall by 4 wide), and the manual calls it z11. Adjacent to it is a very wide (40-pin) connector called L17, and next to that one is a medium-sized (24-pin) one.
    So if you feel like giving it a go, maybe you can fix it yourself. But nobody (especially me) would fault you for taking it to the dealer to have them look at it instead, rather than to trust some random guy on the internet to give you instructions, and to trust that you can take apart your car without breaking anything. ;)
