Oil Filter and Oil Change advice
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by qdllc, Nov 18, 2013.
  1. qdllc
    qdllc Senior Member
    1,370
    399
    Coming up on 5,000. Might do an oil change just because.
    YouTube indicates that the 2013 Prius has an internal filter (not a screw on cartridge like most cars/trucks have). Is this so? Do you have to buy a special Toyota tool or will an ordinary tool do the job?
  2. ksstathead
    ksstathead Active Member
    1,244
    244
    Kansas
    Just buy the filter at the dealer. It is the paper cartridge portion only (plus a new o-ring for the housing), which goes in a reusable plastic housing. The housing in an odd size (64 mm iirc, instead of 65). There is a special tool, but you can use one of the variable size ones for cheap that clamp via springs. Sometimes I can get it off by hand, but don't count on it. The o-ring is in the box with the cartridge.
    As you loosen the housing, at some point it will drain some oil, so have your catch pan there. You can shut off the draining by tightening a quarter turn; it only drains at one point in the rotation.
    You'll also need a small screwdriver to tease open the 3 plastic clips that hold the access panel closed. Don't overextend the panel, especially in cold weather. Many have broken off.
    There are some good pictorials on this whole oil change procedure.
  3. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Oil Changes are FREE the first 2 years or 25,000 Miles which ever comes first. It's called ToyotaCare.
  4. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Oil/filter is not free at 5K. Do it anyway.
  5. ETC(SS)
    6,584
    That's a heckuva good reason! :)
    If I had a new G3...that's when I'd do it.
    Same reason too.
    There's an inexpensive tool that Prius DIY'ers use to remove the canister housing, but since the search function on this site is about as functional and user friendly as the ACA.....I'll leave it up to somebody else to hyperlink that for you.
    Good Luck!!
    At least you will KNOW that the first oil change was done correctly, with the right oil, and that the filter WAS indeed changed. If you take time to mark the replacement filter?
    You'll know whether or not it was changed at the 10K point as well..... :D
    As far as what fluid they use?
    Well..... :rolleyes:
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    or just watch this video
    frodoz737 likes this.
  7. qdllc
    qdllc Senior Member
    1,370
    399
    Saw the video. Don't know why they went to an internal filter. Yes, it may be more ecological, but it's a lot easier (IMHO) to just have a standard screw on filter.
  8. Mike500
    Mike500 Senior Member
    2,593
    764
    If you want inexpensive (cheap), this one fits well;
    If you want a lifetime wrench, this is the Toyota world standard;
    Toyota Lexus Chrome Oil Filter Wrench Tool 09228 06500 02 | eBay
    If the filter housing was installed at the factory and NEVER removed, do as I did, and mark the position with a white paint marker, so you'd NEVER need a torque wrench to retighten it to the proper torque.
    My favorite is this funnel from the Wedco branded oil drain kit. The wide funnel screws onto a standard anti-freeze or windshield washer fluid bottle. I used an old Go-Jo hand cleaner bottle, which is lower profile.
  9. ETC(SS)
    6,584
    HOLY P.T. Barnum, BATMAN!!
    $57 bucks for an Oil Filter Wrench???!!!
    ...uh....I think I'll take the $5 unit. :D
  10. qdllc
    qdllc Senior Member
    1,370
    399
    Did I miss the link to the $5 one? :unsure:
  11. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Try your Toyota parts dept for the filter cap wrench. I found a nice one for $33 that has a ⅜" drive hole on the top. It also fits down over the filter housing and grabs the ribs on the sides.
  12. milkman44
    milkman44 Active Member
    591
    386
    Ky
