2001 ICE Stalls shortly after starting.
Discussion in 'Generation 1 Prius Discussion' started by bobofky, May 8, 2012.
  1. bobofky
    bobofky Member
    107
    2001 Prius with 230,000 miles, replacement hybrid battery in January 2009 at 197,000 miles has recently been having mutliple electronic problems. Current status is:
    o Disconnect the 12 v battery for one or two days.
    o Re-connect the 12 v battery.
    o Turn key and the ICE starts up and runs normally for about 20 seconds, but all warning lights are on: Red Triangle, PS, ! Car.
    o ICE begins to shudder and shake as if it is attempting to engage something that won't turn.
    o After about 15-20 seconds of shudder/shake the ICE dies and nothing will happen until I start over at disconnect of 12v battery.
    I am guessing that the ICE is trying to engage the motor/generator that recharges the main battery, but it is stuck. Is that what is called "the inverter"?
    I appreciate any help or suggestions about how to solve this problem.
  2. ChapmanF
    18,455
    It sounds as if your ICE isn't really starting. You can be fooled because your Prius doesn't have a conventional starter, so you don't have that conventional starting sound. Instead MG1 just spins the ICE right up to operating speed, but then the computer allows it around 15 to 20 seconds to actually start, i.e. reach the point where the MG1 power could be cut and the ICE would keep running on its own. Sounds as if that's what's not happening for you. The roughness you're noticing is probably connected with the ICE's inability to start.
    You'll really want the diagnostic codes as a start for solving the problem.
    -Chap
  3. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    Time the length the engine "runs" with a stopwatch. If it is ~8 seconds (not 20) then dies the engine is not starting. Have the car scanned with Techstream at the dealer. get all the codes/subcodes and share them here.
    If engine oil was recently changed they may have overfilled it, check intake manifold for a "puddle" by looking through throttle body with butterfly open (remove air cleaner first). Too much oil can prevent a Prius from starting.
    If you attempt to start too many times you'll drain the HV battery then you'll be in a bit of pickle.
  4. bobofky
    bobofky Member
    107
    I understand. I have been driving a Prius since March 2001 and I know when the ICE is running. You are right, I do need the diagnostic codes, but I don't have access to a meter at this time. Next move I guess. Thanks.
  5. sbiddle
    sbiddle Junior Member
    29
    Alton, NH
    I had exactly the same issue when I disconnected the 12 volt battery to change out the steering wheel. It's nothing more than the computer getting confused. solved the problem by quickly shifting to neutral once the engine started. I cleared the check engine light with my code reader and after a couple of minutes all the bad lights went out and it operated normally from then on. Do a search and this is a common problem with gen 1 Prii. There's an ECU upgrade of some sort, but it's not that big an issue really.
  6. MacGuffin
    MacGuffin Junior Member
    Los Angeles
    2001 Prius
    Well thanks very much for this, after reconnecting the 12v battery on our 01 I had this same issue where the engine sounded like it was starting but quickly sputtered off and all sorts of warning lights came on. This paragraph above is the only thing I found online mentioning a solution. After quickly shifting into neutral the engine managed to stay on. The warnings and codes remained after restarting it again, since I have no way to clear them. Maybe they will disappear eventually.
  7. 3prongpaul
    956
    730
    Sounds similar to the P3101 and P3191 problem. Clean the throttle body then clear the codes and try to start again.
  8. bwilson4web
    16,330
    I agree: Cleaning Prius Throttle
  9. C Clay
    C Clay Member
    356
    69
    Lexington, KY
    Well.... I having the same issue. I have a 2001 with a remanufactured hybrid battery and a new throttle position sensor that has run fine for months and now this. When I put it in neutral it shutters like the car is going to detonate and explode. I don't have a scanner or the ability to do anything with info on the codes except share with this forum. Maybe I'll get some codes up here soon.
  10. Dman90
    Dman90 Junior Member
    Tracy, California
    2001 Prius
    I
    The issue is the fuel gauge is reset when u disconnect auxiliary battery. If you don't have at leat 3 gallons the car will sometime think it's empty and kick out a p3191 code. Similar to having one bar of fuel and putting in one or two gallons and not seeing an increase. Can also happen if you shift into gear before fuel gauge registers that it has gas. Fill tank, disconnect battery to reset codes then try again to start without shifting to any gears.
