Steelies for Touring?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mkarolian, Nov 20, 2013.
  1. mkarolian
    mkarolian Junior Member
    56
    Boston, MA
    We have a '08 touring and I wanted to pick up some steelies for our winter tires.
    TireRack is showing both of these as fitting our car...
    Offset: 54mmBackspacing: 5.511"Bolt Pattern: 5-100
    Rec. Tire Size:195/55-16
    Offset: 45mmBackspacing: 5.47"Bolt Pattern: 5-100
    I can't image they both fit... help?
    EDIT: We already have 16" winter tires.
  2. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    I would just get some wheels from a Corolla, they would be 15's but they would fit, and should be fairly cheap.
  3. Patrick Wong
    18,210
    6,511
    I agree that you would do better to get 15" steel wheels and use the Prius 15" tire size, 185/65-R15. That will give you a narrower tire which is what you want for a winter tire. Not to mention tires of that size should be less costly compared to the 16" size.
    xpcman likes this.
  4. mkarolian
    56
    Boston, MA
    Sorry, I should have included this in the upfront... we already have 16" winter tires.
    -m
