Best mileage for Fuel Economy
Discussion in 'Prius c Fuel Economy' started by cknitin, Nov 30, 2013.
  1. cknitin
    cknitin Junior Member
    Hi Everybody,
    I've just Ordered my PriusC and should be enjoying it soon. However, I've got some concerns on whether I'll be able to enjoy fuel economy benefits from hybrid system given that I travel rather short distances daily two trips of 25 kms each with some instances of traffic jam.
    I mean, will this be enough distance to charge the electric battery and let us run on gas free?
  2. cknitin
    Hi Everybody,
    I mean, will this be enough distance to charge the electric battery and let us run on gas free?​
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The hybrid system is never just electric or gas, its both. IOW, its never "gas free". Start reading up on the hybrid system around here and you'll learn a lot.
  4. vskid3
    vskid3 Active Member
    773
    228
    25km should be far enough. The main thing is warming it up, which short trips don't allow it to do. Focusing on being in electric mode can actually hurt your mileage. All the energy comes from gasoline. The conversions to charge the battery and then use it to propel the car add up many inefficiencies. The biggest benefits are that you can recapture energy that would normally be lost to braking, the engine can be run at peak efficiency more often, and the engine can turn off when not needed.
  5. fuzzy1
    10,412
    As someone else responded in your other thread, the Prius (excepting the Plug-In version in special circumstances) is never truly gas-free at any distance. For that, get a real electric car (Leaf, Tesla) or longer range, more powerful gas/plug-in hybrid (Volt).
    That said, the PriusC you ordered will beat any regular gasser in the North American market. Elsewhere, some small diesels may outperform the C, but it will depend on the particulars of your commute.
    Your commute distance is just fine for the Prius to do what it does extremely well. Some traffic jams will even improve its advantage over non-hybrids.
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    You're fine. Should see around 50 mpgs easily, if not higher, with 15.5 miles per trip.
  7. ChilldogBoston
    ChilldogBoston Junior Member
    Boston
    My drive to work is 16 miles door to door. Depending on the temperature I can average 55 to 60 mpg. Tire pressure 36 psi front, 34 psi back. Temp 72°F. The average speed for most of my trip is 40 mph. The best day was 70 mpg driving home the first summer after buying the car, but I haven't been able to repeat it. Just about to hit 30k sometime this month. image.jpg image.jpg
    ztanos likes this.
  8. brucepmiller
    brucepmiller Member
    150
    73
    Michigan
    I agree with ztanos. Also, I just discovered that if you look at the "drive information" setting on your car and if you have never reset your trip A computer you can get a readout of your lifetime history with the car. The history on mine after about 24,000 miles is this: average speed - 38 mph; total EV = 35 percent; average lifetime MPG = 52.7. This is really a good little car!
