Random Beeping = Dead Battery...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by froboy67, Nov 14, 2010.
  1. froboy67
    froboy67 New Member
    Boulder, CO
    I own a 2007 prius with around 35k miles on it. I got this car about a year and a half ago, and have ever since had a pretty frustrating problem:
    Every so often when I park my car and open the door to leave, the car will start beeping incessantly, in the same way that it does if you've left a light on. The only indicators on inside the car are the little red car with the key, telling me that I am in fact sitting inside a car with my keys, and the emergency brake light.
    I have looked EVERYWHERE for a cause for this beeping: a turned on light, headlights on, leaving the car on, etc. I've occasionally found that I have indeed left a light on, but generally there's no solution to be found. In this case, I end up just giving up and leaving the car. If I don't come back quickly, without fail my car will be dead and I have to get someone to give me a jump.
    Anyone have any idea what could be causing this? I feel like my battery couldn't possibly be dead already, especially since I've never seen the low battery warning light turn on. It's happened at least ten times now- twice in the last two weeks, but since that it hadn't happened for a few months. Maybe I'm just missing something really obvious... But I have no idea what it is.
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Use the diagnostic mode on the MFD to check the 12v battery voltage. My 1st battery lasted 3 & a fraction years so yoiu are due. Since you already had to jump the car I'd expect to see low voltage readings. If the car won't start, keep trying. It may boot up on the 3rd try.
  3. richard schumacher
    7,664
    1,046
    United States
  4. froboy67
    froboy67 New Member
    Boulder, CO
    On the battery warning light, I just saw some sort of battery light when I was flipping through the manual and assumed that was what it was... But yeah, I guess not. I'll check the battery when I get home and let you know if that doesn't help. Would that beeping be that the car was just telling me it was about to die then? Or could the low battery just be making it act funny?
    Thanks guys!
  5. richard schumacher
    7,664
    1,046
    United States
    Sorry, I wrote carelessly. Lots of people have had dead or dying 12V batteries with no warning from that light. It is easily possible that yours is dying also. The beep could very well be a symptom; any number of odd things can happen when the battery gets low, depending on which computer starts to suffer first.
  6. batteryguy
    batteryguy New Member
    Marlborough, MA
    I have experienced this same problem at least 3 or 4 times. The first couple of times I didn't know why I had a dead battery. The next 2 times, I had taken note of the random/unexplained beeping before locking the car for the night. (Beeping goes away after the car is locked but the battery is dead in the morning.) I could not find anything about this in the manual of course. A few times since, when I noticed the beeping I powered the car on and off and attempted to shut it down again. It seems to need the car to be powered on to the "Ready" state before shutting back down, though I had to try it a couple of times this evening before the beeping went away. It also might have helped to put it in gear, move a bit, and then put it back into park and shut down (or maybe it just needs to be on for a few seconds???) I find this anomalous behavior rather disturbing. I plan to call Toyota and see if I can get any information out of them. Maybe they have a software patch for this bug.
  7. cjarvis
    cjarvis New Member
    Greenfield, MA
    Dealer just diagnosed my car with a dead 12V battery. Symptoms: right after getting gas, the red brake light came on with associated buzzer, as did the check engine light, triangle with exclamation pont, ABS and VSC warning lights. Tried to shut off and turn car back on but wouldn't for about 15 minutes, then started. Lasted another 4-5 miles, happened again but car just shut down. 15 minutes later started and again it occurred about 10 miles later. Got it to Toyota and they diagnosed it as a dead 12V battery and replaced it. Ran fine for a day and it they occurred again (in my driveway luckily) and found the battery was once again dead! They have had it two days without any diagnosis....any thoughts appreciated. Ready to sell and look for an Altima or Insight....I drive 100 miles a day and need a reliable car! Besides my headlights turn off every 5 minutes and if I miss one, the other goes and it is then very dark...different annoying problem I have lived with for two years. Thank you to anyone with thoughts on this battery issue! I've given up on the lights.
    rogerdpack likes this.
  8. Patrick Wong
    18,200
    6,500
    My guess is that the DC/DC converter within the inverter is working intermittently. That would cause the 12V bus voltage to sag, causing the various warning lights to appear as you described. This would also explain why the replacement 12V battery failed. The inverter is covered by the 8 year/100K mile hybrid system warranty.
    Regarding the headlights, I assume you have HID. I suggest that you take a photo that shows one headlight lit while the other is out, and ask your dealer to take care of that problem as well so that you don't have to live with a safety issue. Good luck.
  9. richard schumacher
    7,664
    1,046
    United States
    Another possibility: if 3rd party or aftermarket electronics are present, they could fail and drain the battery without setting any error codes.
  10. froboy67
    froboy67 New Member
    Boulder, CO
    Thanks all. Richard, I tried your battery test procedure and everything appeared normal... Even though my battery had just died a few minutes ago. I've found that if I catch it soon enough I can get the car going by just turning it on and off over and over, so that'll have to work for now.
    Sidenote, I noticed the glove box light remains on even when the door is shut if I have my headlights on. Not sure if that's normal. This shouldn't be a problem since the headlights (and the glove box light) turn off automatically when I turn the car off and open my door, but who knows. I'll go to a dealer soon.
  11. Brian S
    Brian S New Member
    CJarvis-
    It's been a while since you posted anything- I hope your e-mail is still current. My 2007 prius just started to have the exact same issue you are describing in your posts. The dealer also just replaced the battery - and as you said, it just died in my garage.......killin me!
    What did they tell you in the end? I can hardly afford to drop it with them for 3 days of testing so any help would be great! Thanks!
  12. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    I know it may not be the case, but make sure you actually put the car in PARK before you turn it off. Leaving it in either ACC or IG-ON can cause the beeping and also will run down the 12-volt battery. Running the battery down several times will cause it permanent damage.
  13. rogerdpack
    rogerdpack Junior Member
    79
    Enoch, UT
    Any resolution in the end? :)
