Air Ride Installed but need a shock kit
Discussion in 'Gen 2 Prius Accessories & Modifications' started by UGC, Jul 20, 2011.
  1. The green contractor
    The green contractor Junior Member
    Gainesville Florida
    if you still have your struts and the air system i would be interested. as you can see from my profile i carry some heavy loads from time to time and an adjustable air ride would be great i dont care how bumpy it is i have been on the bump styops for so long i dont remember if a good ride ever existed on my car.
  2. Gun owning Prius driver
    397
    78
    Downey, California (Los Angeles Area)
    Any pics of it slammed? I wanna bag my car also
  3. Steven Harvey
    Steven Harvey Junior Member
    96
    Guelph On. Canada
    If your issue is bouncing when going over bumps then it sunds ike you have an issue with your air shock when it goes from fully extended to being compressed. You could try something like this, in the picture below to limit shock travel, and keep your shock closer to the compression side of the equation rather than the extension side. They are called suspension limiters, this may or may not work. Just a thought I had. Mabye mention these to your air ride expert buddies you have and see what they think.
