First Winter Question
Discussion in 'Prius c Main Forum' started by Jcsheridan226, Dec 11, 2013.
  1. Jcsheridan226
    Jcsheridan226 New Member
    Collegeville, Pennsylvania
    Not sure if this question was asked, if so can someone provide link?
    This morning was the coldest(17F) since I've had the C. I was scraping the windshield and couldn't get some areas to come off. I got inside the car and discovered their was frost on the inside of the windshield. Is this normal? I am coming close to my 10k checkup, but wanted to see if anyone else experienced this.
    Thanks.
  2. BigJake
    BigJake Junior Member
    This is eerie! I just turned on my computer and went immediately to this site, planning to post this exact question!! In forty-some years of driving I have never, until this morning, had to scrape the inside of my windshield. What gives???
  3. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    Yep, can be normal in any car. 17 is quite cold, and there was moisture inside and outside the car. Happens to me sometimes because I leave open cans of water in the cupholder. If you want to try to get rid of some of the moisture inside, you can run the AC.
  4. hlunde
    hlunde Member
    419
    75
    Source of water inside the car is most likely from wet carpets -- snow coming off shoes onto the carpet. And, if the temperature drop is abrupt, the windshield is likely colder than the carpets. In other words, the carpets are relatively "warm" and evaporate water into the car's interior.
  5. BigJake
    Sounds plausible but..this morning's circumstances were far from unique. Surely I have tracked snow into cars before and surely it has been cold before and no, I don't have any open cups or bottles evaporating into the cabin. Could the C just be that much more "airtight" than all the other cars I've owned?
  6. fuzzy1
    10,676
    Could the climate control be spending too much time in 'Recirculate', retaining more moisture inside than your previous cars?
    In winter with outdoor parking, I have had to actively manage interior moisture in every car I've ever owned. Flush the damp air outside, sometimes even pull damp floormats into the house overnight to dry.
  7. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    I never use recirculate because the C is very prone to inside condensation, in my experience. This was true for the A/C, I can only believe it would be the same for heat.
    So my guess is that you use recirculate or don't use the climate control very much (no doubt to keep the mpgs from falling.)
  8. BigJake
    Reasonable guesses but, in my case, not correct.
  9. Mendel Leisk
    42,202
    A/C will leave gobs of moisture in the system, regardless of it's set to fresh or recirc. Just try switching it off after it's been running for some time: you'll be battling fogging for the next few kilometers (or miles ;)).
  10. BigJake
    A/C was not a factor.
  11. hlunde
    hlunde Member
    419
    75
    I'm wondering if the Prius has the typical cabin-air exhaust ports at the rear of the vehicle.
  12. fourenty
    fourenty Member
    47
    26
    Endwell, NY (near Binghamton)
    2024 Prius
    Limited AWD-e
    Why would you have to scrape the inside of your windshield? Turn on the front defroster and let the car do it's thing.
  13. fourenty
    fourenty Member
    47
    26
    2024 Prius
    Limited AWD-e
    Are you saying that the fresh/recirculate setting has no affect on how much your windows will fog up? And running the a/c will fog your windows? Really? That has not been my experience.
  14. Fauxknight
    Fauxknight Active Member
    210
    116
    On other vehicles I've had this issue from leaving the vents open, which lets moisture in even if the inside of the vehicle is mostly dry. It's in the teens this morning here, I won't be surprised if I have this same issue when I leave for work soon.
  15. BigJake
    Verrrry interesting!
    Since this exchange, I've spoken to three other people (not Prius owners) who reported the same thing yesterday morning. None could remember it happening before.We had wet snow all day Tuesday then a very cold night. I guess that combination made this possible.
  16. callie0001
    callie0001 New Member
    2013 Prius v wagon
    My V just did this yesterday - - no obvious water inside, doors and windows shut of course, yet the whole windshield was iced over. Running the defrost, A/C etc is hardly an answer - - I didn't have time to wait 10-15 minutes for it to clear. There has to be something wrong for this to happen. I have calls and emails into the dealer, Toyota on FB, and everywhere else I can think of.
  17. callie0001
    2013 Prius v wagon
    It took me 10-15 minutes on defrost! I can't do that every morning ! Wastes time, gas, battery. There needs to be a fix by Toyota!
  18. hlunde
    hlunde Member
    419
    75
    Certain Prius owners have complained about dual images and ghosting when looking through their windshields. I have to wonder if there is something in the windshield construction that is causing both of these issues?
  19. fuzzy1
    10,676
    In the climates where I have lived, it has happened on everything, including Ford, Chevy, Rambler, International, Honda, Acura, and Subaru, not just Toyota. It is something the driver needs to learn to manage.
    Ice scrapers and towels can be used inside too. But don't leave the damp towel in the car, as the moisture will evaporate and then re-freeze on the windshield another morning.
  20. Modelman
    Modelman New Member
    Delaware
    Normal if you have moisture inside the car to freeze. When you use cabin heat, let it be with A/C to dry the air in the cabin. I've had inside frost too, it melts with heat and defrost. Scrape if you must, but it's difficult on the concave inside glass.
