How does one prove he did the required maintenance?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DumbMike, Dec 11, 2013.
  1. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    My maintenance package is over. So, I purchased some oil, filters, etc., and plan to do my own inspection and maintenance. However, I found the below thread here, and nobody answered it. So, I'm restating the question: How do I prove, satisfactory to Toyota, that I did the required maintenance in order to keep my warranty in place? I read a long time ago on this message board that Toyota gave him the run around on whether all of the required maintenance had been completed where he had all of his receipts and records of what he did and when, and even then, Toyota didn't believe him (or something like that). Sorry, but I couldn't find that thread. If I'll get the same runaround, I'll just keep taking my car to the dealership for maintenance. No use in doing my own maintenance if in the end, my warranty is no good. Of course, once my warranty is over, all bets are off and I'll definitely be doing my own maintenance after that.
    Thanks.
    Mike
    Reasons you have been denied warranty claims w/ any Toyota over the years? | PriusChat
  2. frodoz737
    frodoz737 Top Wrench
    4,718
    2,515
    33
    Either keep your receipts or make sure there is a computer record of the purchases and you are golden. ;) There is a law that pertains to this someone here might have reference to.
  3. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Have the dealer do the service
  4. frodoz737
    4,718
    2,515
    33
    Why? When I grew up if you couldn't do your own fluids and filters you were considered a...well you figure it out.
    DadofHedgehog and dbcassidy like this.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    when we had our kia van, all it took for them was a complete spreadsheet listing all the services, dates and mileage. i also had reciepts. that blew them away and they had no problem replacing all the gaskets in the engine that were leaking oil (a big job). they problably wouldn't have done if i didn't have the records they said. oh they also had to replsce the alternator.
  6. ETC(SS)
    7,326
    Inspire3 and frodoz737 like this.
  7. frodoz737
    4,718
    2,515
    33
  8. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    I believe that they have to repair your car within the warranty unless they can prove that lack of maintanence is the cause of the failure. that is how it works if you do performance mods on you car. I have my oil changed at a local oil change place and I keep the recipets they also have my records and that will work showing that it is done. If you do it yourself keep reciepts and write on them the date and miles on the odometer that would work also.
  9. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I keep a detailed spreadsheet with dates, services, parts and supply purchases, mileage, etc. I also keep the services posted on ToyotaOwners.com. I purchase most parts and supplies from the dealership so they have records of the purchases also.
  10. frodoz737
    4,718
    2,515
    33
    Good for you...to few drivers keep a "log book".
  11. Grren4ever
    Grren4ever Active Member
    347
    167
    Well the thing is...even if u bought a bulk 10 pack of oil filters and presented this receipt to the dealer pending their investigation, it can backfire - they can say something like "we know you bought the filters but how do we know you actually changed them every 8,000kms in the oil change?" That would be a tough one to prove.
    Regardless, I am counting on my Prius not breaking down :) and I intend to do the simple stuff myself.
  12. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I'm just going to take it in to the stealership for all maintenance required during the 7 year extended warranty period.
    After the warranty period, I will do all minor maintenance items myself. Other more involved items will be taken to either the dealer or independent shop.
    SCH-I535
  13. frodoz737
    4,718
    2,515
    33
    It is your choice to use the Dealership for maintenance under warranty, but not required and is protected by law.
  14. JMD
    3,779
    1,282
    Good move
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Log book unnecessary. Use there own site toyota.com/owners.
    Its free and you can log all the diy'er you do on the same site the dealer logs all the work they have done.
    Free.
    Dealer has never touched my car for maintenance really. Only time they saw my car was for all the TSB's and one 3/36 under warranty repair for bad front wb. And during on free TSB they did a $59.99 on the rear wheel brakes. I thought that wasn't bad for a pull and looksee and clean & adjust for the rears.
    That $59.99 was the only money they have seen so far. My car has seen Mobil 1 and Redline trans fluid since new.
    The good thing about posting alot of diy info on the toyota site is the dealer see's that and see's your a car guy and they don't even ask you about the gimmicky good-better-best fuel injection cleaning and all the other crap they upsell you. I see the big poster boards everywhere in the waiting room listing all that stuff they must drill every women that comes in but they don't bother me with it.
  16. frodoz737
    4,718
    2,515
    33
    Log Book is a figure of speech. Their site is in essence a log book. :)
  17. ETC(SS)
    7,326
    The burden of proof is on them. Putting in an aftermarket radio does NOT void your warranty....well unless you screw the pooch in the install....and even then, the burden of proof is on them.
    For example....
    You install a cat-back exhaust and your radiator starts leaking.
    Unless they can prove that one lead to the other?
    They have to cover the warranty claim.
    Sometimes...even often times, they will try to bully their way past their obligation to honor the warranty.
    Why?
    Because the customer usually takes their word for it...and because the mother ship will not let the dealer shank them with a $2500 repair bill for an $800 repair.
    THAT's why.
    Also,
    Back in the day...dealerships used to bully people into using them for "required" maintenance.
    Some unscrupulous dealers still do, but usually all you have to do is mention the The Magnuson–Moss Warranty Act and that will usually quell their amorous intentions for your backside.
    Why do you think that many of the OEMs offer free (worth every penny! :) ) maintenance for the first two years?
    Is it because they LIKE you and they want to foster brand loyalty?
    Or....
    Is that they want to see your shiny young face in their dealership waiting room so that they can up-sell you on their 30,000 mile Throttle Body service, or the 20,000 mile HVAC "refreshorizer" or any other "recommended" service that Toyota neglected to put in their maintenance schedule?
    Some people are like new parents.
    They feed their little tadpole $260 a pound infant baby food, and $11 a gallon nursery water, and they buy $36,432 worth of every conceivable toy and safety device and enough outdoor gear to outfit an NFL offense or a platoon of Marines for six months.
    Then?
    After two years or so?
    Your precious little crumb-snatcher is eating off the floor and rough housing with all of the other little tricycle motors in the city park....because you're over the new baby thing.
    Same with cars.
    All very good reasons to do self-maintenance, and if a dealership tries any of that "your warranty is in danger if you don't put nitrogen in your tires!" crap?
    It's usually a good reason to leave the premises and dispatch a few very angry letters to the owner(s) and the OEM vowing not to patronize that shop or that brand ever again.
    Merry Christmas!
    :D
  18. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    Keep receipts and log the events on toyotaowners.com website
    GT-I9505G ?
  19. Mendel Leisk
    41,837
    I keep a text file log, with each entry starting with date and km's. I also maintain a binder with all the receipts. On the front page I make notes, things like torque values, key tag no, etc.
    If for example I'm doing an oil change, I'll purchase the filter cartridge, drain bolt washer and oil (Toyota 0W20) all at one time, at the Toyota dealership parts counter, so I have everything on one receipt. This isn't really a necessity, you can buy supplies wherever, whenever and from whomever (whew) you like, but just seems good corroboration, to me.
    Here's a bit from my log file:
    maintenance log:
    November 19, 2010
    km: 6
    (@ Open Road Toyota - Port Moody)
    *12 volt battery replaced
    Friday, November 19, 2010
    km: 300 (approx)
    (@ XXXXXXXXXX)
    *installed Michelin X-ice 195/65R15 with:
    Corolla 15" black steel rims p/n: 42611-02471-sw (snows)
    With lug nuts p/n: 90942-01007
    Saturday, March 19, 2011
    km: 5112
    *took off snows and re-installed regular tires (in original positions)
    Saturday, May 07, 2011
    km: 7022
    (6 mo or 8000 km service, date governed)
    *changed oil and filter: 4.2 liters new of Toyota 0W20<use 4.0 next time
    *inspected engine air filter: very clean
    *checked coolant, brake and washer fluid levels: all ok
    *checked tire pressures: 42 front, 40 rear
    *lubed hinges/latches
    *checked lights/signals, horn, wipers
  20. xliderider
    8,140
    3,277
    Honolulu, HI
    The site won't even recognize my VIN numbers. Unfortunately, I live in the only state that this does not apply to. :mad:
