Cold start sounds on belt rapping
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zander, Dec 12, 2013.
  1. zander
    zander Junior Member
    46
    connecticut
    This morning I started the car, belt rapping sound, engine check light in on and the car has 68,000 mile on it. Do you think its ok to drive to the dealer. Best advice. thank you
  2. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Does the noise go away after a few seconds?
  3. zander
    46
    connecticut
    As soon as I heard the noises I shut down the car, restarted 1 minute later and the same problem. Now that it's warmer I tried again and the noise lasted for 5 seconds and the check engine light is on.
  4. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    It sounds like the engine knocking problem that plagues Toyotas. If the noise went away but left the check engine light on, you'll need to have that checked, either by the dealer or someone with an OBDII reader and post the code here.
    As far as if it's safe to drive, I wouldn't be too worried as they're pretty hardy and will not normally let you do anything to harm the engine. Be sure the oil level is appropriate and have it checked.
  5. xliderider
    xliderider Senior Member
    8,122
    3,265
    Honolulu, HI
  6. butterball
    butterball New Member
    2014 Nissan LEAF
    Already with seeing you say the car is rattling, I can automatically say that is not good and I would be even hesitant to drive it like that, if it is continuous. I would say get the car towed to a shop immediately to get it checked out before other issues start to occur. Please keep in mind if the check engine light is flashing, that this could be a worst case scenario depending on your engine model if it needs to be replaced.
  7. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Flashing check engine light = replace engine?
    Ummmmm... no!
    This cold start knock is common in some early Gen III Prius's... see post #5 for the link for the TSB addressing this issue.
  8. katkarn101
    katkarn101 Junior Member
    Minneapolis, MN
    I've had about 4 engine knocking episodes over the past 2 years with my 2010 Prius (earlier model before the part change per the T-SB-0010-12). Happened again yesterday but louder than previously. I called the dealership to see about getting the intake manifold replaced per the TSB and was told unless the engine knocking happens at the dealership, they won't do it regardless of the TSB and that it is a known defect/issue recognized by Toyota. My car is currently under warranty and I'm worried by the time I could get it to happen at the dealership it will be past warranty. Has anyone else ran into this issue with the dealership and found a way to get them to do it? Thanks!
  9. ny_rob
    1,968
    813
    L.I.- NY
    Some have captured it on video and presented it to the dealership.
    It's easy to reproduce, so it's easy to capture on video and visit the dealer.
  10. katkarn101
    Minneapolis, MN
    Unfortunately it doesn't happen that often for my car (a couple of times a winter) but it sounds horrible. After it happened on Sunday, I started recording each start but of course it hasn't happened again. This dealership told me it would have to happen there for them to hear and run diagnostic codes on which has a slim to no chance of occurring with my car.
  11. ny_rob
    1,968
    813
    L.I.- NY
    Go to the dealer on Monday evening- park your car there- make sure no one moves it.
    Tues morning or evening (whichever is convenient for you) go there- start your car- only have it run for 1-2 min then turn it off.
    Be at the dealership Wed and have them start the car with you present- it will knock!
    Of course you need cold temps for the three days too....
