Which Rhino Ramps?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bauerhillboy, Dec 12, 2013.
  1. bauerhillboy
    bauerhillboy Junior Member
    22
    I see 3 different offerings from Rhino: 8,000lb that's only 6-3/4" high, 12,000lb, and 16,000 lb. What ones are the Goldilocks ramps for my Prius?
  2. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    The ones with the 4 ton limit are fine. The last two are overkill.
    You are only going to be supporting one end of the vehicle, so even 4 tons is plenty.
    SCH-I535
  3. our1vue
    our1vue Member
    313
    58
    NY
    Something else to consider is the width of the ramps. I went with the 16000 because they were wider than the 12000.
    I can't find how wide the 8000 ones are. I'm paranoid about driving off the side when I'm driving up them :)
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,738
    Bay Area
    I have the 3000lbs each Rhino ramp. Total as a pair is 6000lbs, It works for me so yeah lol.
  5. frodoz737
    frodoz737 Top Wrench
    4,694
    2,494
    33
    Consider that while the ramps must work for the Prius, this is not the only vehicle you will ever own or work on.
  6. Mike500
    Mike500 Senior Member
    2,593
    767
    Unfortunately, I am not an advocate of Rhino Ramps. The original ones were OK, until I ran over them and took a chunk out of the low wheel stops.
    I sold them and got the nesting wide ones rated for 16,000 pounds. They split at the back where they are nested after a couple of uses.
    I'll stick with the more expensive Race Ramps which lift the car an inch higher. The extra inch does make a difference when changing oil.
  7. bauerhillboy
    22
    I thank you all for your comments. I purchased the 12,000lb set because they were available locally and I needed them NOW. My main concern was that the ramps would fit under the nose of the Prius before I drove it onto them. These were perfect in that regard.
    ou812 likes this.
  8. Fostel
    Fostel Member
    96
    29
    Kent
    Excel
    Rhino Ramps $39
    Shipping over the pond 75 bucks the cheapest!
    K&N oil filter $4.5 on Amazon.com
    Nine quid here in the UK on Amazon.co.uk
    I hate this. There is so much great stuff in the US (parts, tools) but shipping and import fees are a killa sometimes.
    I imported some Tekton stuff though (breaking bar, torque wrench, impact reduction bits) and amazing Dynaplugs that saved the day a few times.
  9. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    Well you can certainly get better ramps. Personally, I have had no trouble with my Rhino Ramps.
    However, * always* use jack stands as an extra measure of precaution. Or maybe I'm just super paranoid about it.
