Using iPhone 5 in '13 Prius usb port, cables start smoking
Discussion in 'Gen 3 Prius Audio and Electronics' started by Tom Polous, Dec 16, 2013.
  1. Tom Polous
    Tom Polous Junior Member
    Oak Lawn, Illinois
    Hello,
    Has anyone had a problem with Apple lightning sync cables shorting out or smoking after plugging in an iPod or iPhone into the 2013 Prius' built-in USB port? The cable starts to smoke, suit covers the cable and the 4th pin's contact flakes off. See attached photo.
    The car is only two months old and has been playing audio and charging the phone fine up until the past week. At first I thought it was a bad cable, so I brought the cable to the Apple store they swapped it out with a new one. The new one shorted out after a few minutes, so I got another cable and plugged in a different iPhone 5 - another blown cable. Each time it occurs, there's a message on the screen saying the USB device has exceeded the power requirement (not the exact wording). The phones charge and work fine on chargers inside the house and on computers, so I'm suspecting its the car, but not entirely sure.
    I'm going to make an appointment with my Toyota dealer, but I'm curious if anyone else has had a similar problem? Knowing the dealership they're going to initially put blame on the devices and I don't want to risk damaging my phone to prove a point.
    Thanks!
  2. jehartley
    jehartley New Member
    North East Arkansas
    I think this is an issue with your Prius. I have two 2013 Prius vehicles and I have used the lightening cables in both cars with my iPhone 5S without issue. My wife has also had no issue with her iPhone 5S. Taking it in to the dealer as you have said is the best course of action.
  3. JGI
    JGI Member
    77
    46
    Get a compressed can of air and blow the USB socket on your car. Maybe something got lodged inside and it's causing a short circuit. Looking at the pic, it looks like the terminal got shorted. Have you tried plugging a different iphone/ipad on this car? I have been using mine with no issues.
  4. macman408
    1,179
    368
    I would've agreed with your first instinct that the cable was the problem, but it seems your troubleshooting has made that an unlikely case. I believe there is a chip inside the cable at the lightning plug end, and it's possible that poor power output from the car's USB port is causing that chip to "let out the magic smoke" as those of us in the computer industry would say. (Magic smoke is the stuff contained in every computer chip, and is the basis for how computer chips work. If you let the magic smoke out of the chip, it ceases to work.)
    I'm not sure if the dealer would have the appropriate equipment or knowledge to diagnose a USB port, or if they might just be willing to replace it no questions asked... But if they hesitate, I personally would ask them to hook up an oscilloscope to the power pins and prove that it is indeed 5V (±0.25). My guess is that the car's 12V power might be leaking through instead of the intended 5V power - in which case even a multimeter should show this. A scope would be useful in case there are brief transient spikes on the power.
    This type of failure is what has caused a few deaths in a couple Asian countries from third-party iPhone chargers; somebody plugs their 10¢ off-brand iPhone charger into the wall, and it sends 120V (or 240V) AC to the iPhone (and the person holding it) instead of the intended 5V DC. The 12V found in the car is significantly less dangerous to you, but not to your phone (or even the cable itself).
    elementnomore likes this.
  5. cjs2000
    cjs2000 Junior Member
    Washington, DC
    2014 Prius Plug-in
    Try cleaning out the lighting port on your iPhone. While my cable never got hot, I saw that message about exceeding the power requirement while I was experiencing an intermittent connection issue with Entune. I cleaned out my phone's port and it hasn't happened since. Dust gets in the port, and the cable can't get all the way in I think. Worth a try. I also had some cables work fine and others not. Now they all work fine.
  6. nettels
    nettels New Member
    I'm chiming in late, but I am searching the forums for a lesser heat related issue. My iPhone (lightning) gets very much hotter when I charge it in either the console usb or using a charging adapter in the port under the dash. I use official apple cable, so that is not the issue?
