P0304 cyl#4 misfire
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tomw, Dec 17, 2013.
  1. tomw
    tomw Junior Member
    28
    Milton, ON, Canada
    P0304 code occasionally kept coming up in the last few weeks. After ruling out coils (I swapped them around) and spark plugs I took the fuel injectors off and sure enough cyl#4 injector wasn't spraying nearly as good as the rest. Run some carb cleaner through it and it was as good as new.
    While putting everything back together I must have not lined them up perfectly because I had a leak when I started it back up. I took everything apart and tried it again. This time no visible leak but it the smell keeps coming through the vent while driving. I've ordered new o-rings for the injector since there's gotta be a leak which I can't see but I can smell.
    The way I reinstalled them was I pushed the injectors into the fuel rail and then pushed everything in together. Any other suggestions?
  2. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    Here's a page from the repair manual. Just need to make sure the injector goes in straight and put some gasoline or spindle oil on the O-ring, so it doesn't distort going in. If they've been in and out a couple times, hope the new O-rings come soon.
  3. tomw
    tomw Junior Member
    28
    Milton, ON, Canada
    Thanks. I'm picking them up tomorrow.
  4. Patrick Wong
    18,210
    6,515
    I hope that you will be replacing the O-rings for all four injectors.
  5. tomw
    tomw Junior Member
    28
    Milton, ON, Canada
    Yes, all 4 are getting replaced
