Aero efficiency - with or without moonroof?
Discussion in 'Prius c Main Forum' started by mnaf, May 7, 2012.
  1. mnaf
    mnaf Junior Member
    36
    SF Bay Area
    One of the first things I noticed when I saw the Prius c in person were the deep channels in the roof of a non-moonroof level 3.
    On moonroof versions the channels are almost nonexistent - barely visible behind the glass portion of the roof.
    Any thoughts on the effect that the moonroof might have on aerodynamic efficiency (i.e. mileage) of the c? Or is this just splitting hairs? It's a fairly large physical difference.
    Thanks
  2. F8L
    19,011
    4,081
    Grass Valley, CA.
    At low speed it would likely be insignificant because aerodynamic drag is very low. At high speed it could be much more significant but I couldn't say how much. I have the same question regarding the GenIII solar roof.
  3. dano9258
    dano9258 New Member
    59
    Las Vegas, NV
    Crap, should have passed on the moonroof then lol.
  4. AutoMo
    AutoMo Junior Member
    61
    33
    Eastern WA
    Any money you spend on a passively open sunroof, will more than offset the extra cost of fuel you burn running the AC or heat. I drive mine like I stole it, my rational is that no matter what I was driving it would not get as good of MPG as my C. 36k and still running great.
    Mark323 likes this.
  5. orenji
    orenji Senior Member
    5,884
    3,486
    Just drive it slow, no worries then! ;)
    vernon birdman likes this.
  6. AEROENGR
    AEROENGR Junior Member
    57
    Connecticut
    I think the reason for the channeled roof cross-section on the Prius family is to reduce the frontal area. It's a small effect, but Toyota has used many small refinements to incrementally improve the aerodynamics and the fuel mileage. The numerous small increments add up. The boundary layer is probably tripped to turbulent by the upper edge of the windshield, so the effect of the sunroof is small. The effect of the cross-section may not even be measurable in a wind tunnel. They just did it because it's definitely favorable for drag, even if the benefit can't be quantified.
  7. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    I've driven the same 100miles+ stretch of 65mph+ highway with my C2 and moonroof C4 and there really isn't any noticeable MPG loss/gain
  8. flotowngtm
    flotowngtm Junior Member
    42
    22
    I am sorry to tell you guys that the channels you see on the roof have nothing to do with aerodynamic or fuel efficiency but they don't. They are there for Structure.
    Any time you have a flat sheet of metal the bigger you make it the flimsier it becomes. Think about holding out a thin metal sheet in your hand that is only 1ft long it probably wont bend but if you hold out in a 6ft metal sheet that's the same thickness it will start to bend under its own weight. You can either make it thicker to accommodate for this or you can press ridges into it that eventually make it smaller sections instead of one big section. This gives the roof more strength.
    It almost breaks the roof up into 3 sections as opposed to 1 big section.
    The reason its smaller on the roof with the moon roof is because the roof section behind the moon roof is much smaller and not as much is needed to make it sturdy.
    All vehicles have this. Even in places that you cant see. Like the floor boards under the carpet and the interior door panels. This is nothing specific to Toyota.
    Way back in the day in the 40's and 50's manufactures figured this out and quit making the panels on cars thicker and started to press sections in them to make them just as strong.
    And with the presses going front to back along with the air flow they have no effect on aerodynamics
  9. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    This is not an issue. Sorry, you'll have to worry about something else.
    Mark323 and flotowngtm like this.
  10. Isn't the one with the sunroof like a half inch taller? That shouldn't damper fuel economy that much.
  11. flotowngtm
    42
    22
    OMG !!!!!!!!!!!!!!!!!!
  12. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    Sunroof adds weight too. Every ounce counts in the 1/4.
  13. koipond
    koipond Member
    198
    40
    I drove to work with snow on the top of the car. When I got there the snow was blown off the front of the roof near the top of the windshield... but had remained on the top of the car where the sunroof is. Based on this observation of airflow I doubt that the sunroof is adding any drag in comparison to the standard "deep channel" roof contour.
    SCH-I535 ?
  14. Ken Scheinker
    Ken Scheinker Junior Member
    I wouldn't drive a car without a sunroof. Living in Seattle I am lumen starved and driving a closed cabin would drive me nuts(er). I rarely open it for air, sucker is noisy, but having light when you want it is so nice. That's why I didn't go with a full size in part, sunroofs are a high end option and push the price way up. Being said, I avg. around 48-50mpg in mixed driving.
  15. Mark323
    Mark323 Junior Member
    69
    Got the sunroof to blow around what hair i have left... if i get balder(er) will this reduce drag? lol-j/k
  16. mahout
    mahout Active Member
    655
    116
    NC
    My experience with aero improvements on cars says the moonroof will have more negative effect on aero than the grooves; the grooves are there probably to meet roll-over standards and are parallel to air flow while the moonroof is vertical and thus will result n more drag.
  17. mahout
    655
    116
    NC
    That the snow remained on the sunroof is a good sign air flow was deflected over it and in doing so increased drag.
  18. Mr Incredible
    955
    506
    Neb
    While the regular Prius has a CD of .25, the C has a .28.
    Would you think the CD of .28 with an increased height of .75" with a sunroof be increased to, perhaps, .2805 or .2806?
    Would that be more or less efficient than carrying around the weight of having a full tank vs half a tank? Or would it be irrelevent compared to any number of the daily variables contributing to more/less mpgs?
  19. koipond
    koipond Member
    198
    40
    But the roofline up to the point where the moonroof starts is pretty much the same between both versions... so the same airstream coming off the windshield would probably be similar either way.
    SCH-I535 ?
