Lower grille replace
Discussion in 'Gen 3 Prius Accessories and Modifications' started by milkman44, Dec 15, 2013.
  1. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Just before it got cold here, I had a little mishap. A chicken crossed the road at the wrong time and wound up stuck in my grille. When I got home and looked, the chicken was still alive but it's foot was hung in the grille. In less time than it takes to tell, the dog grabs the chicken and after the third lunge, he took off across the yard with the chicken squaking and spewing feathers everywhere. The grille was pushed loose and a couple of the upright braces between the bars is broke. I pulled it back into place the best I could. I ordered a new grille and will replace it along with my new grille block invention, but just want to know if I can replace it from below without taking the bumper off. What with knee surgery and the cold, I haven't had a chance to check. I'm right at the 100K mark so will change oil and the grille at the same time while on the ramps. Appreciate any info.
  2. Tony D
    Tony D Active Member
    469
    132
    Dublin, Ireland
    Any word on the chicken?
    mroadster2k likes this.
  3. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    You might be able to access it from either above or below without taking the bumper off.
    From above, remove the cover above the radiators.
    From below, remove the front spoiler cover.
    I haven't had a reason to do this myself, so let us know how it works out...
  4. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    It begs the question..."why did the chicken cross the road?"... LOL
    What is your new grill block invention - care to share details?
    Omar Haddad and milkman44 like this.
  5. milkman44
    591
    386
    Ky
    When the new grille came, I made a cardboard template to cover the entire girlle, I have it on now, but need to do some final sizing to make it fit better, painted black and held with two wire ties. After I get the fit just right, I'll post some pics. The chicken crossed the road because he was on the wrong side, I just don't know why he went there in the first place. It was a Game rooster, so maybe there was one on the other side that needed a whoopin'.
    Tony D likes this.
  6. milkman44
    591
    386
    Ky
    Changed oil today and looked at replacing the grille. No way from the bottom or the top, so the bumper has to come off or everything pulled loose except the fasteners across the top under the hood. Then maybe the bottom would pull forward enough to get the grille out. I will get a picture of the grille block.
  7. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I'm not sure but I think if you remove the black plastic part under neath the bumper you can then access behind the grill to release the tabs holding it. I had removed that panel at one stage to install 4" HID driving lights which required cutting the grill.
    I would have shot the dog and saved the chicken. At least you get eggs from chooks. you only get crap from dogs.:D
  8. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    The real important question is how is the chicken?????
    Tony D likes this.
  9. milkman44
    591
    386
    Ky
    Sorry, the chicken didn't make it. :(
    Tony D likes this.
  10. milkman44
    591
    386
    Ky
    I still have the old grille and finally got a picture of the sheet metal grille block that I cut out and painted, put the door edge trim around the sharp edges and used two wire ties to mount. Will try to post the pic. GrillBlock[1].jpeg
    xliderider likes this.
  11. Jon Stapel
    Jon Stapel Junior Member
    45
    Cheswick, PA
    could you salvage a dinner out of it?
  12. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    That would look cool with some Fying Tiger-like snarling teeth on there. :D
    milkman44 likes this.
  13. milkman44
    591
    386
    Ky
    I like that, want me to PM you my address?:D
