Strut dust boots necessary?
Discussion in 'Generation 1 Prius Discussion' started by Wisco, Dec 26, 2013.
  1. Wisco
    Wisco Member
    116
    Quick question for anyone who has an opinion..
    While mounting my winter tires I noticed the plastic boots protecting the shaft on my front struts are in tatters.
    I expected to find replacement boots with a slit down the length that would easily slide on and be held by some sort of zip tie. Instead the only ones I find are tubes that require disconnecting the strut to slide the boot down.
    Are these dust boots worth my time? The struts seems fine (look good, passed the bounce test). I can slice a pair of boots to slide them on, but maybe I should save the $30.
    Car is a 2002 with 166k. I'm not sure of the age of the struts.
  2. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    They are there to stop dirt and stuff getting down into the shock itself and therefore prolonging its life. If it was my car, I'd replace them if they were shot
  3. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    I wold bet that over 50% of the older cars on the road have torn strut dust boots. They are there to keep debris off but really do not help to much to prolong. In my opinion if the strut was operating how you like it and that was the only reason you would disassemble the strut for I would not do it. Mine are also all torn up on the Prius I just purchased but my struts are also all shot I think and at 140,000 may be the original so I will be looking at replacing when and if I do them.
    TomK
  4. Mike500
    Mike500 Senior Member
    2,593
    767
    For a car that OLD, I wouldn't worry about it. If and when the struts "shocks" go, I'd replace them then.
  5. Patrick Wong
    18,204
    6,505
    The bounce test is useless.
    Your front struts are definitely worn out at 166K miles, if original.
    I suggest replacing the boots when the struts are replaced. Good luck.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    My advice is as tempting as it is, don't take short cuts.
    My old Honda Accord needed new struts and boots, creaked like an old sailing ship going over speed bumps.
    I agree that at 166K miles it's probably time to replace, and whether needed or not, I'd throw the extra $30 in the pot and get the boots.
  7. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    It does not sound like he wants to replace the struts, just was wondering about the dust boots being torn to pieces.
    Unless he has owned the car for awhile and knows the history, for all he know the struts have been replaced twice already. If it just your boots, let it ride.
    Opinion worth price charged.
    TomK
  8. Wisco
    Wisco Member
    116
    Hi all,
    Thanks for weighing in. After I posted the question I thought "why am I bothering folks on priuschat to ask if I can avoid fixing my car". But I'm glad I did.
    It seems that if I'm concerned about the long term longevity of my struts I should fix the boots.
    If I'm not concerned about getting every last mile out of struts that might already be going out, I should forget about the darn things.
    I'm in the first category, so I'm going to do something about them. Apparently you can't buy slip-on boots that can be installed without pulling the strut. I'm certainly not going to pull my struts, so next time the ice melts I'm going to patch them up and try to resecure the boots to the struts. It won't last forever, but it will keep the gravely slush out.
    Thanks again.
  9. Mike500
    2,593
    767
    I have a 15 year old Mazda MPV with the same problem. I just cut away the residue of the boots.
    The reason they don't sell the split boot is that, while desirable, the boots do not directly affect the function of the hydraulic cylinder.
    Ride on, forget them, and replace them with the hydraulics when you need to.
    Georgina Rudkus likes this.
  10. Coots
    Coots Member
    62
    25
    Hailing from parts unknown, Iowa
    So much misinformation in this thread.
    Yes, they help prolong the life of the strut. Just an example, but think of the minerals from rain water that can affect the strut shaft. Tiny sand and dust particles. If they didn't matter, Toyota would not have included them in the first place. Can you get away without replacing them? Probably. Will the life of your strut be reduced? I guess you'll never know one way or the other. But they DO help to protect the strut shaft from debris, dust, and sediment.
    No, they are not. They are only worn out when they fail, or on their way to failure (leaking, getting softer over rebound and/or compression, etc). I had a 96 accord with 225,000 miles and the struts we perfect.
    My 2010 Prius struts have lasted 229k miles, until the front driver strut failed, leaking fluid. The rest are just fine.
