unlock Park
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Husni, Dec 28, 2013.
  1. Husni
    Husni New Member
    `Amman, `Amman, Jordan
    i have a 2009 prius and few days back my car got heated and switched off by her self, when it turned off it activated the park mod in the middle of the street, so the question is how do i unlock the park to push the car away from the street.
    51,835
    if you mean it won't shift into neutral/drive, you might need a new 12v. not sure what you mean by overheated? did the coolant leak out/fan stopped working/thermostat fail? you could try disconnecting and reconnecting the negative 12v battery cable.
  3. Husni
    Husni New Member
    yes i found out later that the fan cables were disconnected, but at that moment when i pressed the power button, the car started with an error because the overheat but i couldn't shit it to natural so i can push it away from the street, so i was wondering if something similar happens again how i can shift it to natural while i can't get it to the ready state?
  4. bisco
    51,835
    temporarily disconnecting the 12v negative for a minute resets the computers. this may work for you, but i'm not sure.
  5. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Unfortunately the shift lock actuator, or parking pawl motor, is difficult to access, as it is also a theft deterrent. There is a way to make the actuator to run if the car is not doing so, as a result of error conditions, in the post from imwoody36:
    How do you put the Prius in neutral to push or tow it? | Page 2 | PriusChat
    I haven't tried this, but this is the best that anyone has mentioned. There are other posts here, that mention using a wheel dolly under the front tires. Do a search for "shift lock actuator" for more ideas on how to move a dead Prius.
    It is necessary to put the car on a lift so that one can get under the transmission if, as a last resort, one has to unbolt the parking pawl motor. Big hassle.
    Husni likes this.
  6. Husni
    Husni New Member
    Thanks for your replies :)
  7. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Try putting the Prius in ignition on mode. That requires two pushes of the power button WITHOUT holding your foot on the brake. You should be able to shift to N and get the car off the street as long as the 12 volt is working for you and not discharged. The 12 volt is not a real strong battery, so it won't last a long time in this condition. To turn off simply push the power button one more time and the Prius should power down.
    Don't forget to hold down the brake pedal when attempting to shift to N from P.
  8. nh7o
    1,686
    340
    Hawaii
    If the car goes into N as Ron describes, then you can pull the PCON relay (under the hood) out before turning the car off again. That will keep the parking pawl motor from operating, as it usually does on shut down. Then you can tow the car in the off state, and no worries about the 12V going flat. The foot operated parking brake will still work.
