Want to Raise a 2012 Pip. How Big A Rim Can I Use?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by kenmce, Dec 31, 2013.
  1. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    Should have a 2012 Pip next week. My old Prius didn't have enough clearance for my part of the world. Seems to me that a bigger rim and a bigger tire should raise me up a little. Anyone know if this works? Are there problems? Will it screw up my speedometer? Can I go from the stock 15" to say 17" rims ??
    Also, can I assume that almost anything off a third generation Prius hatchback can be moved into a 2012 Pip?
  2. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
    I am sure your Speedometer will be off. Don't know of any other problems other then maybe fender clearance
  3. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Not necessarily, you speedometer will depend on the final size of the tire not the rim .
    Yes you could go with Prius plus rims 17" fittment and speed will be just fine
    But it seems like you should look in to getting coil overs because getting bigger rims to improve ground clearance isn't the way to go usually it requires lower profile tires.
    Or you could get 17" rims and bigger tires and use this tool to see what would really happen with the speedometer many members have Prius plus rims with any problemsTire Size Calculator - Compare Tire Sizes
    Yes, almost everything can be used from the non-pip to the pip with the exception of some items, tires and rims are definitely interchangeable.
    kenmce likes this.
  4. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Seventeen inch Prius 5 wheels with 215x45x17 tires would be a easy swap with no effect other than a small loss of MPG. Actual "lift" would be marginal and wouldn't be cost effective unless you want a better look..
    Priusmpg likes this.
  5. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
  6. ETC(SS)
    7,140
    TruckNutz: Optional.
    giora and markabele like this.
  7. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    How utterly rediculous.
  8. markabele
    5,084
    1,782
    Nebraska
    In the most awesome way possible!
  9. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    One mans trash is another mans treasure I guess.
  10. kenmce
    1,544
    515
    NY
    AAaauuugghhh! No! ETC(SS), get out of my head!! OUT Damn you, OUT!
  11. Mendel Leisk
    41,402
    You're understating that the "lift" would be marginal, LOL. You'd actually being lowering the car, by a miniscule amount:
    215/45R17 has smaller outside diameter than 195/65R15.
    My 2 cents to the OP: leave it stock for a while, the madness will pass.
  12. kenmce
    1,544
    515
    NY
    I am not being whimsical or trying to make it stylish. I am starting out with a new Prius. With the old one I was forever brushing the chin air dam against hills and driveways (I live in hill country) I am hoping that if I can get the new one to sit a little higher I won't have this problem. I tend to keep cars for a long time and try to take good care of them.
    I don't actually know what controls ride height in a Gen III, but I'm pretty sure someone in here does, and will tell me if it can be adjusted just by changing to a taller or bigger tire.
    Also, what's a coilover?
    Easy there big guy. He's a newbie, needs our help getting up to speed. We can always harass him later...;)
    Priusmpg and -1- like this.
  13. ETC(SS)
    7,140
    I've always felt the same way about some of the things that kids do to their cars today.
    Tomorrow those kids will have their own kids that do something goofy to their rides "just like everybode else" so that they can be.....
    different. :rolleyes:
    I believe that you have to ride YOUR ride.
    Not mine.
    FWIW?
    I think that slamming or the blacked out "somebody stole my rims!" look is about as jacked up as the kids that put 44's and 12" body and frame lifts on their trucks, or the other folks that put $8,000 worth of rims on a $500 10-year-old primered out Impala. :D
    To each his or her own. :)
  14. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    Very true!
    Very true!
  15. Mendel Leisk
    41,402
    FWIW, Honda markets (or did in recent past) a Civic model in some South American countries, that's got 1~2 inch greater ground clearance. Just by reworked suspension. In consideration of rougher road condtions.
    I wouldn't have minded getting one of those, after trying to impersonate a snow plow once or twice.
    Near the bottom of the main article here:
    Honda Civic - Wikipedia, the free encyclopedia
  16. markabele
    5,084
    1,782
    Nebraska
    You do realize it is meant to be ridiculous, right?
  17. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    if you pick a larger diameter tire you can keep the 15" rims and gain ground clearance, unfortunately you can only gain about 1/2" that way without being too far off speedometer/odometer/computer/steering wise.
    I don't know the exact diameter that is too much but you can definitely go to 25.5" diameter on 15" rims (about 817 RPM or 205/65/15)
    You can target the same diameter tire at any rim size, doesn't matter if it is 15", 16" or 17" rims just target the largest diameter tire that fits the wheel well.
    If the diameter of the tire is too large you'll rub the wheel well so any more than it takes to rub and you have to modify the suspension.
  18. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Other than the mentioned speedometer error and rubbing issues, a larger diameter wheel/tire will place more mass further away from the center of the wheel. This will affect gas mileage because it will be harder to rotate the wheels. Think of it like constantly driving up a slight hill.
    Being a PIP, that will mean shorter EV driving range over OEM wheel/tire size.
    SCH-I535
  19. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Coil overs increase or decease ride hight and tune suspensions
    A coilover is an automobile suspension device. "Coilover" is short for "coil spring over shock". It consists of a shock absorber with a coil spring encircling it. The shock absorber and spring are assembled as a unit prior to installation, and are replaced as a unit when the shock absorber has leaked. This provides for optimal damping without torsional loads. Some coilovers allow adjustment of ride height and stiffness, using a simple threaded spring perch similar to a nut. More advanced adjustable coilover systems will use a threaded shock body, coupled with an adjustable lower mount for ride height adjustment, while an adjustment knob is used to adjust damping, commonly referred to as "stiffness." Spring rate also plays a role in stiffness.
  20. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    Given the cost, minimal lift (half your tire diamater increase), hit to mpg and making speedometer off, you might be better off:
    1) cutting off the lower lip of the front air dam. Cheap, will probably gain 1" (or a bit more?) of clearance where you actually want it.
    2) Mild suspension lift with using spacers to raise existing springs* or other suspension raising mod that will have less negative ride, control, tire wear problems than the 'hitting stuff' problem you have now that you are trying to lessen.
    I'd certainly search/ ask on the larger Gen III Prius Acces. & Mods thread since they have been around much longer and have a much larger experience pool because there are simply so many more Gen III's on the road than PiP's.
    * I have no idea if theses are made, just a thought.
