Ice storm 2013: Toyota Prius powers Thornhill man's home
Discussion in 'Gen 3 Prius Accessories and Modifications' started by arnesto, Jan 5, 2014.
  1. arnesto
    arnesto Junior Member
    24
    San Diego
    News / GTA
    Ice storm 2013: Toyota Prius powers Thornhill man’s home
    Bob Osemlak lost power for nearly a full day on Dec. 21, but was prepared to go much longer using his car’s battery for electricity.
    Text size:​
    Increase
    Decrease
    Reset​
    Share via Email
    Print
    Report an Error
    Save to Mystar
    ANDREW FRANCIS WALLACE / TORONTO STAR Order this photo
    Retired Air Force mechanic Bob Osemlak demonstrates on Saturday the system he rigged up allowing him to use his Prius to power his house for two days during an outage caused by the great ice storm of 2013.
    By: Kim Magi Staff Reporter, Published on Sat Jan 04 2014
    EXPLORE THIS STORY
    1​
    Save to Mystar
    • Share on Facebook
    • in​
      Share
    • [​IMG]
    Republish
    One man’s transportation is another man’s generator.
    Or at least it is for retired engineer Bob Osemlak. During theice storm, he powered his furnace, lights, refrigerator and TV using only his Toyota Prius.
    The Thornhill resident lost power for nearly a full day on Dec. 21 — a fraction of time compared to others affected by the storm — but he was prepared to go much longer with the idea of using his car’s battery for electricity.
    “I’ve been an aircraft technician for over 50 years, and I’ve also worked on cars,” said Osemlak, who was in the Air Force for more than three decades. As such, he doesn’t recommend anyone try the technique themselves in the event of power loss, as it could be very dangerous.
    More Video
    • [​IMG]Video:Hume: The Year of the Idea
    • [​IMG]Video:Ice storm: Residents frosty as gift cards run out
    He planned for a potential outage by installing an outlet on his furnace and ran the cord through the basement window to his hybrid electric car.
    Power was conserved by rotating between heat and electricity.
    “When the furnace comes on, and the house gets up to temperature, I go to the thermostat and shut the furnace off,” he said. “Now I can plug something else in: the TV, the fridge or the floor lamp.”
    He said if you only power the lights and TV, the traction battery should allow it to run for a long time. Out of the nine hours he used the Prius during the outage, the car’s fuel gauge, measured in bars, went down by less than one bar — close to a gallon’s worth of gas.
    His daughter Robyn had no idea her dad had planned for the outage in this way.
    “The Prius supplied them with warmth, entertainment, and fresh food (while) they were off the grid,” she said.
    Osemlak has always been a do-it-yourself kind of guy, Robyn said.
    In the 1960s, while stationed in Winnipeg, he created his own automatic car starter.
    “I used to be on shift work . . . I didn’t want to go out and have the car(not start),” he explained.
    He created a starter that had the car run every hour for 10 minutes in the frigid winter temperatures.
    “It wasn’t exactly warmed up, but it was warm enough that it didn’t make that grinding noise when it started,” he said.
    As it happens, the power came back on for the Osemlaks shortly before midnight on the 21st. He went out the next day to refuel just in case it should go out again.
    A diesel Volkswagen owner for a decade, he switched to a Prius a few years ago, hoping for similar mileage.
    So far, he’s definitely getting his money’s worth.
  2. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
  3. matt b.
    matt b. Member
    251
    60
    L.A.
    Way to go bob !! we go from a multi purpose vehicle to quadruple purpose vehicle way to go Bob.
    Brilliant ;)
  4. bisco
    52,274
    was he running an inverter off the 12v, or was this a full on hybrid battery generator?
  5. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I suspect the reporter had no clue what the guy was talking about, as this is the only mention of the connection in the story:
    "He planned for a potential outage by installing an outlet on his furnace and ran the cord through the basement window to his hybrid electric car."
  6. bisco
    52,274
    agreed. judging from the fact that he had to switch back and forth from heat to electricity, he's probably just running a 1000 kw inverter off of the 12v like so many here are doing. 'don't try this at home, you might hurt yourself'.:p
  7. Old Smokey
    Old Smokey Junior Member
    thornhill on
    Hi every one, I was running a modified seine wave 1500 watt inverter, Iwas being carefull not to bloe the 100 amp fuse.
  8. bisco
    52,274
    thanks bob, were you running it off the 12v battery terminals?
  9. bisco
    52,274
    can't tell from the pic what it's hooked upto.
  10. Old Smokey
    thornhill on
    yes i ran of the 12volt battery terminals,i used welding cable bolted to the inverter with heavy duty battery clamps they are hard to squeeze , the hookup heavy duty and flexible and i can use it on other cars, I also used a heavy duty extension cord.
    Tracksyde and bisco like this.
