km/hr VS. mi/hr
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by tonia taffaro, Jan 3, 2014.
  1. tonia taffaro
    tonia taffaro Junior Member
    83
    somehow - dont know what happened - my speedometer changed from mi/hr to km/hr. does anyone know how to change it back to mi/hr?
    i have read thru the manual 3 times and cannot find any instructions...
    49,909
    on the liftback, there's a button on the dash to the lower right of the steering wheel with interior light switch, gas door button etc., and i'm always bumping it. maybe c is similar? manual should show it in the beginning with the description of gauges and controls.
  3. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Same buttons you use to set the clock. Just right of the wheel. Mph /kph Min. Hrs.. H
  4. You know how you can cycle through your trips, like where says "TRIP A," "TRIP B," and then "ODO" for Odometer? There's a "TRIP" button on your steering wheel.
    With the car on, press the "TRIP" button to cycle around to "ODO" - make sure it says "ODO" on the screen before continuing.
    - Then hold the "TRIP" button. This switches to/from metric.
    - This won't work if the screen still says "TRIP A" or "TRIP B" - you'll reset your trip info if you do this and you'll have to start over.
    minkus, Tideland Prius and ztanos like this.
  5. fourenty
    fourenty Junior Member
    46
    25
    Endwell, NY (near Binghamton)
    Not the case with the C
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I answered this last week... if the above answer doesn't work. Try doing a search. It's been answered a lot.
    Rob.au likes this.
  7. Tideland Prius
    16,230
    Yeah for the other Prius owners, the Prius c doesn't have a dedicated km/h-mph button like the rest of the Prius line up has. I think it's through the black "button" that cycles through odo and trip odo like what Skylis says.
  8. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    On the c it's a steering wheel button.
    The clock setting procedure is also clearly totally different (using an appropriate sequence of using the DISP and TRIP buttons in conjunction with the Multi-information display.
    Sometimes the c is totally different from a liftback. ;)
    Also note the mph to km/h feature doesn't exist in all markets (eg. the Australian c stays steadfastly metric, as it should (y) )
    minkus and GrumpyCabbie like this.
  9. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Well that's just not right... what if I wanted to drive to America from Australia? :ROFLMAO:
  10. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    Yours can switch to metric, so you have no problems if you want to drive to Australia. Clearly no-one would ever go the other way. :p
    rcortespr and fourenty like this.
  11. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Ouch...:oops: ha ha
    Rob.au likes this.
  12. HaroldW
    716
    95
    My gen3 2014 switches to MPH but all other measurements stay metric. H
  13. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Ours is the exact opposite here.
  14. DKTVAV
    DKTVAV Active Member
    510
    101
    My friend also from Sydney is thinking about moving to the US(y) I'm gonna tell her to buy a PC to drive here:D
    ztanos likes this.
  15. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    There was a time when Google Maps would give you directions (by, at some point, telling you to swim or kayak across the Pacific Ocean). I assume the laywers put paid to that. :rolleyes:
