Transmission leak, engine has to come out...
Discussion in 'Gen 3 Prius Main Forum' started by pumalex, Nov 14, 2013.
  1. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Thanks for posting that Jimbo! I always thought the Prius combined HP was about 130 but according to this manual it is more like 170hp. o_O
    Hybrid Component Locations & Descriptions (Continued)
    Specifications
    Gasoline Engine:
    98 hp (73 kW), 1.8-liter Aluminum Alloy Engine
    Electric Motors
    80 hp (60 kW), Permanent Magnet Motor
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The electric motor can only add HP that the battery supplies, when it is using electricity that the engine supplies, that merely transfers HP, none is 'new'
    So the total is 134, although the PIP may be higher.
  3. Feri
    Feri Active Member
    761
    144
    Thanks Jimbo. Something number law of thermodynamics.(y)
  4. unterhausen
    unterhausen Junior Member
    64
    State College, PA
    It's interesting that there were no symptoms other than the leak. The thread about the transaxle replacement is in the Gen II technical discussion forum LINK Transaxle Failure | PriusChat
