oct 2012 Truestart battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JC91006, Jan 15, 2014.
  1. JC91006
    JC91006 Senior Member
    16,724
    8,546
    These Toyota 84 month batteries are really not that good. I'm charging one up from Oct 2012 and the battery won't hold beyond 12.5 volts. Started at 12.4 volts, put in on my 2 amp charger for 8 hours and it won't fully charge. For a 1 year old battery and it won't charge to 12.9, something is not right with those batteries.
  2. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Has the battery been fully or well discharged, and then recharged by the Prius. The OEM battery has a maximum charge current limit of 4.5 amps, and the Prius can recharge it at more than 10 times this limit. It is my belief that this dries the battery out, and causes it's early demise.
    The charger must also be suitable for AGM batteries a flooded lead acid battery charger will likely under charge it.
    John (Britprius)
  3. JC91006
    16,724
    8,546
    This battery has never been discharged. It's always been in the car and I just wanted to charge up the batteries in my car since I had my charger out.
  4. Britprius
    5,194
    1,921
    I edited and added a line to my post about chargers did you read that.
    John (Britprius)
  5. JC91006
    16,724
    8,546
    I'll run it in the car for a while and take another reading. My charger is just a generic battery charger.
  6. Britprius
    5,194
    1,921
    This "may" be the problem. AGM batteries require a higher charging voltage than standard car lead acid batteries. The charger needs to have a voltage output of 14.2 to 14.3 volts to get the battery at full charge.
    John (Britprius)
  7. JC91006
    16,724
    8,546
    I don't have starting problems, just figured it would be better to top off the battery while I have the charger out. I'll just leave it alone
  8. Britprius
    5,194
    1,921
    The Prius charging system is quite good at keeping the battery topped up if the car is used on a regular basis. But the battery is rather a week link.
    I use a 62 Ah mobility battery that fits snugly in the OEM position. These batteries are truly deep discharge batteries, and will put up with lots of abuse at a price well below the OEM.
    John (Britprius)
  9. JC91006
    16,724
    8,546
    Now that I've purchased a 2006 from a member here, I'm starting to drive that much more. My 2008 has 126,000 miles and I don't want to cross the 150k mark until 10 years comes around. This 2006 I'm driving now has 117k miles and I can put more miles on that while going easy on my 2008. Therefore it's not driven as much anymore. I don't think the battery will be an issue, it doesn't sit for weeks at a time. I hate moving my accessories from one car to another, I hate these problems of having 2 cars.
    I bought a 2010 for myself and my wife had the 2008. The 2010 has been taken from my possession because of the wife.
  10. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    JC, As John (britprius) stated above the charger you have doesn't sound like it is designed for AGM type batteries.
    I too have one of the "True Start" brand batteries from Toyota. It is now 12 months and ten days old. I keep it charged up with a smart charger set a 4 amps on the AGM setting and have no problems getting the battery up to 12.9 on the MFD and 13.1 with a digital VOM at the posts.
    I would suggest you look into getting a newer smart charger than has the AGM settings on it. I use the Battery Minder 12248 and it works great for me. Others on this board recommend the CTEK brand of chargers. Those too also offer the AGM settings. As mentioned, the parameters for charging a AGM type battery are not the same as a standard flooded battery. The voltage cutoff is much lower on the flooded type versus the AGM setting. Also if you continue to charge the battery with a standard charger, you will shorten the life span of the AGM battery as you are not "fully" charging the battery.
    BatteryMINDer Battery Charger / Maintainer with Desulfator — 12 Volt 2/4/8 Amp, Model# 12248 | Battery Maintainers| Northern Tool + Equipment
    CTEK Multi US 4.3 - CTEK Battery Chargers
    Hope this info helps!
    Ron
  11. JC91006
    16,724
    8,546
    Thanks Ron, very helpful information, as always.
  12. dorunron
    3,318
    1,105
    Houston, TX
    If you have a northern tool store close to you, go buy one of those Battery Minders. I had a 30 day return option on the one I bought. I bought it two years ago when the old OEM battery was getting weak. That should tell you how much I like it and that it does the job. I would have taken it back if it did not work as I paid around $130 for it. I am a poor man on disability so I don't tend to throw my money away. I think you will be pleased with your investment.
    cyberpriusII likes this.
  13. cyberpriusII
    1,153
    1,727
    Mars Hotel
    $130...yikes....I was thinking about replacing our charger -- but it still works perfectly, just not AGM -- as I remember, paid about $50 for it five or six years ago.
    This is the one I now have and as far as I can tell, would not want to use it on the Prius battery....Battery Charger, 12V (SE1250 ) at Aubuchon Hardware
  14. Patrick Wong
    18,200
    6,498
    It's better than not using a charger at all.
  15. dorunron
    3,318
    1,105
    Houston, TX
    I would not hesitate to use it if I needed a charge. Just need to understand that it might not "fully" charge your battery. That does not mean it won't charge it up enough to get the Prius in ready mode if you happened to run down your battery.
  16. JC91006
    16,724
    8,546
    Well good news, my 84 month battery is actually charging up to 12.8 volts after 15 months of use. It was my charger that was not able to charge the battery fully, the max it would charge up to was 12.5 volts. After running the battery in the car for a week, it was able to hold a charge of 12.8 volts. You guys were 100% correct with your analysis, it was definitely the charger.
  17. Britprius
    5,194
    1,921
    You are not the first person to be caught out by the charging requirements of AGM batteries nor will you be the last. The difference is not easy to understand, but as stated previously the voltage for AGM batteries needs to be at leased 14.2 volts. Charging with some flooded lead acid chargers results in under charging and possible battery damage from sulphation if left in that state.
    John (Britprius)
    dorunron likes this.
  18. Patrick Wong
    18,200
    6,498
    Since I have several DC lab power supplies around, my idea of a 12V AGM charger is to set a power supply with 3A output to a voltage output to 14.4V. The result is constant current charging until the current drops below 3A; then constant voltage charging at 14.4V beyond that. I find that a Prius AGM battery in good condition will be charged up when the current flow drops down to around 60 mA or so. If the current flow remains substantially higher, that is a clue that the battery is showing signs of deterioration, but it can still be kept in service.
