PIP charging cable won't click into the car
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Nathan505, Jan 15, 2014.
  1. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    If you look at my avatar you can see it- that "O" ring is greenish..
    On my actual OEM Toyota handle it's orange.
    52,095
    i would think it's a weather seal, but it might just be a cushion when the plug seats.
  3. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    My handle is a blue SVCC Sumitomo. The inside of my black plug looks just like yours, except where your green seal is, I have an empty ≈3/16" groove around the I.D. Does everyone have an orange or green seal in that groove?
    (Leaving no nit unpicked, I don't think it's actually an o-ring ... a gasket in the form of a ring with a circular cross section... ;) )
    retired4999 likes this.
  4. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Please don't use WD-40. It's a terrible lubricant,and worse still it's a solvent that will dissolve plastic. It's also toxic. Try dielectric grease, which is silicone based and wont attack the plastic - or you.
  5. ny_rob
    1,968
    813
    L.I.- NY
    Sure sounds like your handle is missing the "O"ring.
    If mine continues to act up- I'll pull it out.
  6. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    Did you get a ChargePoint branded charge (110) cable with your PiP? Or is that a cable from a commercial public charger (or one that came with a 220v charge station)?
  7. bisco
    52,095
    my blue simitomo has the orange gasket. now that i look closely, i see that it's set behind some holding clips and the top has an ear that goes up into a slot. i notice also that it isn't all the way back, there's about an open 1/4" behind it.
  8. Nathan505
    Nathan505 New Member
    Just a follow-up. My charger without the o-ring is working fine. Thanks for the tips here, fellow PIP-ers.
  9. bisco
    52,095
    i wonder if they deleted it on the '13's?
  10. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    Good question. Any 2013 (or 1014) PiP owners care to say if they have a green or orange rubber ring inside their charge handle? (also say what charge handle you have please)
    This morning I looked into the car's charge port. About were the rubber ring would be, there is a discoloration or non shinyness around that place. I'm guessing that the ChargePoint plug my wife uses at work has this rubber ring and that the mild dirtiness or abrasion of daily use leaves a slight visual trace where the rubber ring sits.
  11. mrbigh
    3,686
    699
    Long Island, NY
    I checked my OEM EVSE wand and it has an orange ring inside and it show to be sort of deformed by use. Daily use after 20 months.......
    I have another OEM evse that I bought out of ebay,(unknown Prius model year) brand new to carry in the car in case of an emergency/convenience recharge, and it doesn't have the sealing ring inside of the wand. It must be a moisture prevention device.
    I'm including some pictures
  12. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Mine has the orange o-ring inside as pictured by mrbigh.
  13. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    My 2013 PiP OEM charge handle has none but I have had no problems (after only a month:D)
  14. retired4999
    2,652
    627
    Eau Claire, Wi.
    Same here orange o-ring.
  15. bisco
    52,095
    this is weird.
  16. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    Oh Crap! When I bought my PiP, I thought the salesman (at the drive thru window) asked if I wanted "onion rings" with that (PiP). I said no thanks, I'm not hungry. He must have said "O" Ring! :ROFLMAO:
    rogerv and bisco like this.
  17. ny_rob
    1,968
    813
    L.I.- NY
    Seems us 2012 PIP owners have the orange "O" ring in the OEM Toyota EVSE handle and maybe Toyota either removed it from the 2013 EVSE handle or modified the handle so it doesn't require an "O" ring any longer?
  18. mrbigh
    3,686
    699
    Long Island, NY
    The SAE J-1772 EVSE equipment can't be modified in its receptacle and/or in the matting connector.
    The handle with out the connector is another issue.
  19. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    2013 owner has an orange o-ring.
  20. CharlesH
    2,797
    1,163
    Roseville, CA
    Very early 2012 PiP here. Orange O-ring in J1772 handle.
