plug in navigation
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by fumbling, Jan 17, 2014.
  1. fumbling
    fumbling Junior Member
    17
    irvine
    do the plug in prius base or advanced have the 7" HDD navigation?
  2. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
  3. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    The base also has navigation on its smaller 6" screen
  4. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    The base has a 6" display but does not have HDD navigation.
  5. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    The 6" display Nav in the base PIP is pretty lame and it's expensive to update maps.
    Many here use a Garmin or other portable GPS that are more reliable and include quarterly map updates.
    CaliforniaBear likes this.
  6. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    And it mounts very nicely in that little window to the left of the dashboard.
  7. dkelly
    dkelly Member
    118
    Gilbertsville, PA
    That's where I mount my iPhone with the TomTom app. My only issue is routing the power cable. Right now I just drape it over the steering column.
  8. bisco
    51,915
    coming soon: phone, scan gauge, gps!:p
  9. CaliforniaBear
    1,180
    289
    Northern California
    The Garmin power cable is a reasonably small size. What you see in the picture is the only exposed part. It runs from the 12v socket, under the driver's seat, under the floor mat, up behind the parking brake area, excess cable in that nice cubby hole to the left of the parking brake, then pushed into the molding slot along the door jam up to the top of the dashboard.
    Unfortunately that may not work well with the much thicker cable they supply with the traffic capability. I don't commute so I don't care about the traffic info.
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    Is this your wish list?:)
  11. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    And if Garmin has their way, a dash cam too!
  12. bisco
    51,915
    oh yeah!;)
  13. bisco
    51,915
    and i'll take that too!(y)
  14. bisco
    51,915
    all wrapped up where the mfd is!:)
  15. CaliforniaBear
    1,180
    289
    Northern California
    They already have a limited set of gauge measurements that can be made with their "Garmin ecoRoute HD Vehicle Diagnostics Communicator HD" using Bluetooth communications to some Garmin GPS units. However, it didn't work in my PiP and I'm very happy with ScanGauge.
  16. bisco
    51,915
    your garmin looks nice there, where do you put the scangauge?
  17. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    Hmmn, I was getting ready to sell our old [pre (us) smartphone] Garmin Nuvi 360 with our replaced car for $35. We use Mapquest or WAZE Apps mostly for nav, but now makes me wonder if the old Garmin might be worth hanging on to.
  18. retired4999
    2,652
    627
    Eau Claire, Wi.
    (y)
  19. CaliforniaBear
    1,180
    289
    Northern California
    Its a bit tricky. Glue won't work. I drilled 2 very small holes in the mounting area that should be easy to patch and hard to see if the gauge is removed. I used a steel wire to attach a plastic strip. The whole "dashboard" cover in that area just snaps off so you can run the wire and twist it tight. Then I used the Velcro method to attach the gauge.
  20. bisco
    51,915
    i love it!(y)
