Electric "Heater In a Box" System
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Michael33, Jan 8, 2014.
  1. bisco
    52,220
    i bought something in a mesh bag at home depot (looked like small white gravel) that you hang in your basement to dehumidy and remove odor, then place in sun to dry out. let us know how it works, if it keeps the windshield dry, that would be epic!
  2. Astolat
    Astolat Member
    229
    73
    Guildford UK
    The one I mentioned on the long thread about electricity to heat the car is similar, but you 'recharge' it in a microwave. My experience is that it might help very slightly, but it certainly isn't a solution.
  3. bisco
    52,220
    yes, i put a few up around the basement without much success. broke down and bought a dehumidifier for the heavy summer humididity.
  4. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    They are only good for small confined space.
    The unit USB bought is specifying 'effective for up to 500 cu. ft.' (I think) so, on the face of it, it should be good for the job.
    Looking forward to test results.
  5. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    You could use Lithium iron phosphate batteries that are drop in replacements for car and/or motorcycle batteries. Weigh only 1/4 of what typical deep cycles weigh and they don't mind being left discharged.. They are expensive though.
  6. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    That's the problem. If I could get a standalone LiFePo battery for even twice as much as SLA or lead-silicone, I'd suggest that.
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    It is heavier than I expected. It is about 2 lbs. I guess it makes sense because there are a lot of silica gel crystals.
    I had it for 2 days and have made a few trips with it. It DOES NOT eliminate fogging up inside. However, it reduces greatly and I think it is a must have for PiP owners.
    It extends the time it takes to fog up inside. Even if I start to see it forming, I open the window and it clears up faster. After closing the windows, the fogs don't come back as quick. This was with 2 passengers in my PiP.
    The first time I tried was on my morning 10 miles commute and I left it in the car overnight. The front windows and windshield started to fog up fairly quickly and I thought this thing does not work. After more testing, I think what happened was due to the difference in temperature of my warm garage (therefore car interior temp) and the outside.
    One thing I noticed, the hatch window did not fog up. I will test more and report back. I may try putting it in different locations. I have it in the storage compartment under the flying bridge.
    I took a pic to show the size of it in relation to the dash and the head unit. It IS NOT where I leave it while driving so DON'T drive around with it on your dash.
    IMG.jpe
    iplug, drash and giora like this.
  8. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Location (together with time of exposure) may be the key.
    Remember, this things are working on diffusivity (no circulation of air) which is a slow process.
    iplug likes this.
  9. bisco
    52,220
    how does it operate, is there a battery? do you put it in the microwave to dry it?
  10. bisco
    52,220
    i wonder how long a 12v lithium tool battery would operate a 12v heater?
    markabele likes this.
  11. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    No battery, basically same as what you hanged in your basement but in a nicer box and indicators and means for regeneration.
    From what I read, you plug it in to the wall for regeneration (by internal heater?) in an open space (unless you want to humidify the room...)
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    No battery. Crystals are the "battery".
    You plug it in to dry out the crystals. It has electric element inside. I guess I could dry it out in the sun too.
  13. bisco
    52,220
    that's pretty cool! (y)
  14. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Several seconds to maybe a minute, I'd guess. The battery would probably overheat.
    If you're talking about a chemical dehumidifier above, I suggest trying it with a small, low-volume fan.
  15. bisco
    52,220
    how come they can operate a leaf blower for half an hour?
  16. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Electric motors require substantially less power than resistance heating, which is pretty much the Champ at using energy.
  17. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Agree. This technology is also made for relatively small spaces with the low diffusivity you mention - such as a closet or closed washing machine to dry it out.
    However, the cabin of the car is functionally a very large space because the air inside is turned over rapidly every time one opens the car door or breaths for a few minutes, overwhelming the product's ability to rapidly control these humidity swings.
    Certainly worth the test, and great if it can slow the window fogging process substantially.
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Drove 18 miles today in 27 deg F. I ran the cabin heat in air recirculate mode and it fogs up much slower (3 ppl in car). This thing is already saving energy.
  19. bisco
    52,220
    cabin heat as in 'ice is on'?
  20. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Yes, I can't get all 18 miles in EV so I used gas and cabin heat strategically.
    Lourun likes this.
