Heated? rear quarter light
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Sagitar, Jan 20, 2014.
  1. Sagitar
    Sagitar Junior Member
    59
    Ampthill
    The offside rear quarter light on my right-hand-drive PiP has what appears to be a heating element similar to the one on the rear window.
    I cannot find any reference to it in the handbook and I'm puzzled why it is there.
    Any ideas?
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    This question seems to come up from time to time....
    It's an imbedded antenna for the radio.
    Priusmpg likes this.
  3. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Its called a grid antenna just like ny_rob stated.
  4. mrbigh
    3,686
    699
    Long Island, NY
    it's an antennae to detect....... Zombies proximity, then the self destruct gets activated...
    bisco, priuskitty and Priusmpg like this.
  5. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    good thing Toyota is keeping it real by warning us of... Zombies
    bisco and priuskitty like this.
  6. Sagitar
    59
    Ampthill
    Thanks very much. I thought it might be something like that, but it's still a bit puzzling because the car has a normal antenna on the roof.
  7. CharlesH
    2,796
    1,163
    Roseville, CA
    On the PiP there is:
    1) An AM/FM antenna for conventional radio.
    2) A GPS antenna for the navigation system.
    3) A Sirius/XM satellite radio antenna.
    4) On the Advanced, a cellular antenna for the Safety Connect radio, which also supports the Advanced Applications such as vehicle locating and charge management.
  8. mrbigh
    3,686
    699
    Long Island, NY
    and there is another for HD radio, and XM/Sirius reception and another for Cellular communication for the Advanced model ....
  9. CharlesH
    2,796
    1,163
    Roseville, CA
    As I understand how HD radio works, it is on the same frequency as standard AM/FM, just squeezing a digital signal in the same channel as the conventional analog signal. So I don't think that a separate antenna is needed for HD Radio.
  10. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    The roof mounted antenna is for radio and XM (IIRC, the XM antenna module appears in the service manual at the base of the roof mounted anntena). The window grid antenna is there for (radio) antenna diversity, I believe
    Antenna diversity - Wikipedia, the free encyclopedia
  11. Tideland Prius
    16,555
    It's the "diversity antenna" so you do have more than one AM/FM antenna. It's for better radio reception.
  12. Sagitar
    59
    Ampthill
    My thanks for all the responses.
    I feel much better informed.
    Best wishes.
  13. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    Any idea where these are?
  14. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    The navigation antenna is under the dash, on the driver side, it looks like (the following image is of the upper dash assembly, flipped over, notice were the center 2 air vents are)
