jump starting ?
Discussion in 'Gen 2 Prius Main Forum' started by brin wood, Jan 22, 2014.
  1. brin wood
    brin wood Member
    100
    upstate NY
    Does it take a special connector for jumper cables, as I have been told, to use jumper cables on a Prius? What are the details? If so, where can I get them?
    thanks
  2. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    nothing special in the cables per se...but be careful in jumping other cars. Getting a jump from another car is easy. Use the 12 V (connector?) jump point under the hood, over far right under the red tab/cover. for negative use the bolt that holds the front strut, very near the red 12 V tab/cover.
    I've successfully jumped a mini-cooper: make sure the Prius is in Ready mode and connect jumper cables like normal. Press the gas pedal in the Prius and get the engine to run, maybe 5 minutes. disconnect all cables, THEN try to start other car. Under no circumstances should you attempt to start the dead car with the Prius connected! Repeat if the car won't start. I did this twice and then enough juice went into the mini-cooper to get them on their way. YMMV, of course.
  3. Patrick Wong
    18,200
    6,500
    Your safest bet would be to purchase a portable jumpstart device (which is plugged into 120VAC house current for recharging). Then you can carry that around in the hatch, and use that if needed on the Prius. If called upon to be a Good Samaritan, you can use the portable device without any concern about damaging the Prius.
    Meg&Bear and koolingit like this.
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    Just pls make sure you don't reverse polarity. This can kill your inverter
  5. cyberpriusII
    1,155
    1,762
    Mars Hotel
  6. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    It is not necessarily the case that pressing the gas pedal, in Park, will charge the HV battery, if that is what you are indicating. A force charge is done by going into D, with the brake pedal pressed, and then pressing the accelerator pedal.
    Running the engine up on a donor car is the usual practice, as that gets the alternator up to speed.
    There is no alternator in the Prius as in a conventional car, so it does not need to have the engine running. The 12V system is charged from the HV system, and will send charge into another 12V battery connected in parallel. If the HV battery gets too low in the process, the Prius will automatically run the engine as required to keep the HV battery sufficiently charged, without any intervention from the driver.
    Meg&Bear and finman like this.
  7. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Gen 3 demo. OP has a Gen 2.
    The Gen 2 positive terminal under the red cover is a little smaller and somewhat more of a challenge to attach the positive clamp for some jumper cables (the clamp can be too big for the terminal).
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Meg&Bear likes this.
