The info has arrived! 2007 Camry Hybrid
Discussion in 'Other Cars' started by galaxee, Feb 28, 2006.
  1. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    okay. the promotional packet has arrived. it is here. on our coffee table. one night only. it's going back tomorrow.
    i wanted to get this up and rolling, so think of questions as i work on typing all this stuff up. it's gonna be a looong post and might take a bit. but i'm working on it i swear!!!
    :D :D :D
  2. galaxee
    9,810
    471
    MD
    Features
    Standard features
    P215/60R16 tires with 16-in alloy wheels
    TPMS
    Halogen lamps with auto on/off
    DRLs
    Heated dual color-keyed power outside mirrors
    SKS
    Cruise control
    Maintenance indicator
    Optitron meters with instant FE meter and multi-information display
    JBL premium AM/FM/MP3 6-disc changer with bluetooth, 8 speakers, 440-watt output
    homelink
    Aux jack
    Auto-dimming electrochromatic mirror with compass
    Power windows with driver's express down
    Dual zone automatic climate control with electric AC, pollen filter, rear vents and "plasmacluster"
    Leather wrapped steering wheel and shift knob
    Manual tilt and telescopic steering with audio/bluetooth/climate controls
    Vehicle dynamics integrated management (VDIM)
    Rear center headrests
    60/40 folding rear seat
    Chrome exhaust tip
    Cargo net
    Optional features
    NAV with JBL premium AM/FM/MP3 with 4-disc changer, BT, 8 speakers and 440W output
    Power tilt/slide moonroof with rear personal lamps
    Leather-trimmed interior with driver and front-passenger heated seats
    Unique styling cues
    "Special" front grille
    Blue tinted headlamp reflectors
    Acoustic front windshield
    LED taillamps
    HSD badging
    Miscellaneous cool stuff from the book
    Electric power steering
    Speedometer/multi-information display: provides trip info and power flow/FE data. instantaneous FE meter replaces tach
    They didn't show a picture so i'm having a hard time picturing this, but "the meter's blue rings correspond to the average fuel consumption figure, the brightness of the rings change depending on the level of efficiency during the drive"
    How cool does that sound.
    And oh, oh, oh do i wish the Prius had this:
    ECO HEAT/COOL BUTTON
    "when engaged, the system allows the engine to shut down when stopped under a wider range of driving conditions for greater efficiency and reduced emissions. it does this by reducing heater and a/c output"
    And NO FUEL BLADDER (same system as the HiHy- airtight metal fuel tank)
  3. galaxee
    9,810
    471
    MD
    Specs
    Engine
    2.4L 4-cyl DOHC 16 valve with VVT-i
    Bore and Stroke: 3.48x3.78 in
    Compression ratio:12.5:1
    HP: 147@ 6000 rpm
    Torque: 138 lb ft@ 4400 rpm
    Ignition: Toyota Direct Ignition
    Fuel system: EFI
    Fuel: Regular unleaded
    Emissions control: AT-PZEV
    Electric motor/generator/power storage
    Permanent magnet synchronous motor
    Electric motor power output: 108 kW @ 4500 rpm
    Torque: 199 lb ft@ 0-2000 rpm
    Battery type: Nickel-metal hydride (204 1.2 volt cells)
    Nominal voltage 244.8
    Transmission: ECVT
    Capacity: 6.5 Ah
    Battery peak HP rating: 45
    Max voltage: 650
    Hybrid system net horsepower: 192
    Fuel economy
    43/37, 40 combined (preliminary EPA estimate)
    Zero to 60 in
    8.9 seconds
    Suspension
    Front: independent macpherson strut with stabilizer bar
    Rear: independent dual-link with stabilizer bar
    Stabilizer bar front/rear: tube, 24.2/15.9 in
    Brakes
    Front- ventilated disc (hydraulic with power assist) and electronically controlled brake system with integrated regen system
    Front diameter: 11.65 in
    Rear- solid disc (hydraulic with power assist)
    Rear diameter: 11.06 in
    Parking: foot pedal
    Swept area: front/rear 237.6/192.2 sq in
    ABS: standard
    Tires and wheels
    Wheel size: 6.5x16 in
    Material: alloy
    Tire size: P215/60R16
    Tire type: all-season steel radial
    Spare: temporary
    Steering
    Type: electric power assist rack and pinion
    Overall ratio 16.0:1
    Turns: lock to lock 3.2
    Turning circle: 36.1 ft
    Exterior dimensions
    Wheelbase: 109.3 in
    Overall length: 189.2 in
    Overall width: 71.7 in
    Overall height: 57.5 in
    Tread width: front/rear 62.0/61.6 in
    Minimum ground clearance: 5.9 in
    Drag coefficient .27
    Interior dimensions
    Headroom front/rear without moonroof: 38.8/37.8 in
    with moonroof: 37.9/37.8 in
    Leg room: 41.6/38.3 in
    Shoulder room: 57.8/56.7 in
    Hip room: 54.6/53.9 in
    EPA passenger volume: 101.4 cu ft w/o moonroof
    99.7 w/moonroof
    EPA cargo volume: 10.7 cu ft
    EPA class: midsize
    Capacities
    Engine oil: 4.3 qt
    Fuel tank: 17.1 gal
    Vehicle mass
    3637 lb
    Max towing weight: 1000 lb
    Warranty
    Comprehensive 3/36
    Powertrain 5/60
    Corrosion perforation 5/unlimited
    Hybrid component 8/100 (15/150 in CA emissions states, except hybrid battery which is 10/150)
    Safety
    7 airbags standard: front, side, side curtain, driver's knee
    Side impact door beams
    3 point seat belts for all seats, emergency locking retractor on driver's belt, automatic/emergency locking retractor on all passenger belts, adjustable shoulder on front seat belts
    ABS with electronic brake-force distribution brake assist
    TPMS
    VSC and TRAC replaced by VDIM
    Childproof rear locks
    DRLs
  4. galaxee
    9,810
    471
    MD
    [edit: consolidated into post 3]
  5. mdmikemd
    mdmikemd Member
    436
    Minneapolis
    Many thanks! I almost feel that when it's available, the minivan is going back...I'm just dreaming.
  6. galaxee
    9,810
    471
    MD
    [edit: consolidated into post 2]
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    You mean 43/37 ?
  8. Godiva
    Godiva AmeriKan Citizen
    10,339
    Would that be heated seats? Heated LEATHER seats? And a leather steering wheel?
    This could be a car my Mother could love.
    She is not so happy with the Caddy any more. They just put over $600 into the engine and then the car got hit in the parking lot and there's minor body damage that's another 1200.
    Does it say anything about seat adjustments? Programmable or height,tilt,etc?
  9. galaxee
    9,810
    471
    MD
    workin' on it. in short, yes i think so. [edit: 8-way power driver's seat]
  10. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Here are a few things:
    Standard
    Optional
    Does this meant that when you add NAV you loose 2 CDs?
    Also:
    Fuel economy
    Capacity
    Fuel tank: 17.1 gal
    700 miles on one tank? For me, that would be a refill every 17 commuting days. Three weeks if driving alone, more than five when carpooling.
    Lastly:
    Thanks G! :wub:
  11. Tideland Prius
    16,621
    So basically the ECO HEAT/COOL button is similar to us turning off the A/C at lights to stop the engine from running and turning it back on when the light goes green (in the winter).
    The cool thing is that the MFD is standard, not optional. Also, galaxee, if you've ever been in the new IS, that's probably what they're talking about. The new IS has these rings on both speedo and tach. I'll use the tach as an example. If the tach approaches the redline, it goes from blue to orange and when it's really close to the redline, it turns red. I assume there's some ring of light around the FE needle on the Camry that performs a similar function.
    Edit: There's something that still bugs me. It says it has rear disc regenerative braking. The only way this can have it is if it's AWD and so far, Toyota has yet to tell us if it's FWD or AWD.
  12. priusblue
    priusblue New Member
    152
    Thanks for the info galaxee! We need to get you a scanner!
  13. Frank Hudon
    Frank Hudon Senior Member
    4,147
    nooooo typing slow=errors, typing fast=more errors :lol:
  14. galaxee
    9,810
    471
    MD
    :lol:
  15. malorn
    malorn Senior Member
    4,281
    59
    "Somewhere in Flyover Country"
    What does it cost?
  16. eak354
    eak354 Member
    447
    HI
    thanks G!
    *wipes drool*
    everything sounds great!!
  17. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    The person from Toyota we talked to was thinking about $30,000.
    Yes, the seats are heated, no there is NO Backup camera. And for those of us in California- the 64 thousand dollar question- NO it will NOT get Carpool stickers...
    Sorry to burst your bubble.
  18. galaxee
    9,810
    471
    MD
    Tideland- think i found the answer to your regen question:
    it says there's regen on the front, no mention of rear regen. methinks it's FWD. :)
  19. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Nor will it be eligible for them under the new New York law. I'll have to look it up to check VA laws.
  20. daniel
    14,487
    1,519
    Spokane, WA
    I drove a regular Camry once (loaner during recall service). I thought my Prius was the better car.
    If they are estimating an EPA rating of 40 mpg combined, that means real-world 35 combined, or 10 (?) less than the Prius.
    Yep, I'm still driving the better car.
