Engine wouldn't shut off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by red prius 1948, Jan 25, 2014.
  1. red prius 1948
    red prius 1948 New Member
    My Prius engine wouldn't shut off when the button was pushed. The Toyota dealer was clueless.
  2. Mendel Leisk
    41,642
    My first thought is there's some mechanical problem with the power button, something hanging up. Does it feel normal? Try pressing repeatedly, at different angles.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    ....and with that lack of detail and information, I'm clueless too....
    But yeah....the machine is designed to turn off. If yours isn't...pursue it with the service department until you find an answer.
  4. red prius 1948
    It's a hatchback. It felt normal, and did eventually go off when we got to the dealer. My concern is that they couldn't find anything wrong, and it might happen again.
  5. bisco
    52,092
    how long has it been running? does it turn on and off like normal, or does the engine not stop at all? did it shut down when you ran out of gas? did you try disconnecting the 12v battery? how was the battery charge indicator behaving during said problem? you might have hv battery issue.
    btw, welcome to priuschat!:)
  6. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Thread moved from the Prius v forums to the Gen II forums.
  7. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    Can you be more specific. Were you stopped, in drive or park etc. The reason I am asking the start/stop button does different things depending on the conditions when it is pushed.
  8. vskid3
    vskid3 Active Member
    773
    228
    Did you try holding it for a few seconds?
  9. rjparker
    10,238
    6,390
    You may have a bad display module. Power button is part of the problem, Toyota has extended the warranty on this part. Especially if the problem is repeatable. I carry my 2008 Prius notification in the glove box, you probably got one also but may not have paid attention. Nevertheless, the dealer can look it up.
    Update: The TSB 0172-09 is attached. Here's a link to a Combination Meter thread.
    SFO likes this.
  10. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    I agree with rjparker, although the part in question, subject of the warantee extension, is more properly called the "Combination Meter", and the thing fails in all sorts of ways. Not turning off is one of them.
  11. bisco
    52,092
    and yet, the dealer was clueless. how sad.
  12. Jackson123
    Jackson123 New Member
    Gila Bend, az
    I have a 2004 prius and does the same problem. I read about combination meter. And I go to ebay, to repair it. It cost about 150 dollar. I replace and solve the problem.
    How to replace: On step 15 don't forget to remove to bolt that hold air bag. I am not read it carefully and almost give up.
    gen ii prius - combination meter removal
    ingineerix.com/cmremoval/
  13. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    I've had this happen on three occasions to my 2005. In all three cases I was able to power down after about 5 minutes. It hasn't happened in years. I figured one of the software updates took care of it. If its hardware then its extremely intermittent in my case.
