Torque Log Analyzer for Google Drive
Discussion in 'Prius OBDII Third-Party Apps' started by Alessandro71, Sep 15, 2013.
  1. Alessandro71
    Alessandro71 Junior Member
    I've made a prototype of a Log Analyzer for Torque, that computes some driving parameters.
    It's particularly aimed for Toyota HSD hybrid cars.
    It's written in Google Script for Google Drive, so it can be used on as many platforms as possible.
    You can find it here:
    pleasedonttouchhescreen.blogspot.it/2013/09/torque-log-analyzer-tool-for-google.html
    I'd appreciate some feedback from some other hybrid car owners.
  2. Alessandro71
  3. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi Alessandro71,
    I've just added Shift Lever position sensor, you can also use that for logging N "gear".
    Column 1
    0 [TH]Name[/TH][TH]ShortName[/TH][TH]ModeAndPID[/TH][TH]Equation[/TH][TH]Min Value[/TH][TH]Max Value[/TH][TH]Units[/TH][TH]Header[/TH]
    1 [TR][TD]Shift Sensor SW - N[/TD][TD1]N[/TD1][TD1]2125[/TD1][TD1]{A:5}[/TD1][TD1]0[/TD1][TD1]1[/TD1][TD1]Off/On[/TD1][TD1]7E2[/TD1][/TR]
    Vincent
  4. Alessandro71
    thank you vincent
    your work is the foundation on which i build mine
  5. Alessandro71
  6. Alessandro71
  7. Alessandro71
    Added Orion BMS log file format
    If you have a plug-in conversion kit on your Prius, check it out
  8. Alessandro71
  9. Maxroach
    Maxroach New Member
    London
    I just found out this tool exists - I am definitely installing now to investigate a similar issue
  10. PeterPrius2007
    PeterPrius2007 Junior Member
    47
    Kitchener
    Really great tool. Worked wonderfully on my Prius!
  11. Sezy
    Sezy Active Member
    437
    229
    37
    Saint Charles, Missouri
    2020 Prius Prime
    This is what I get trying to do the Add-on after signing into Google.
