How to extend LIMITED SERVICE LIFE of Prius PHV traction battery.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by CraigCSJ, Feb 24, 2012.
  1. retired4999
    2,652
    627
    Eau Claire, Wi.
    You set your timer so that it completes it's charge shortly before you drive off, it starts and stops charging all on it's own.
    I have only 10,000 miles of all EV miles and about 6000 miles of HV. I do not notice any difference of lower capacity from when it was new. The computer regulates battery SOC you do not have to worry about it at all!
    Hope this helps! :)
    PriusC_Commuter likes this.
    51,915
    agreed, i don't recall seeing any complaints here regarding reduced capacity. except for everyone's first experience with winter!:p
  3. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    Awesome! It's "winter" here and the car is reporting 16.4mi for a full charge. But I prefer blended drives due to a 90 mile RT commute (no office charging).
  4. 3PriusMike
    3,100
    2,419
    Silicon Valley
    My actual estimated miles is still relatively high and about the same as last year at this time -- I'm at 12.9 miles.
    However, I do notice that the actual number of kwh, as reported by the ChargePoint L2 charger has decreased. In the very first few months (summer) I would see 2.8 to 2.9, typically for a full charge...once 2.95. This past summer I would see only about 2.6 - 2.7 kwh for a full charge (this is driving EV only down to 0.1 or 0.0; not driving in HV and using another 2-3% or whatever amount it drops after that). The main thing is my measurement technique has been consistent.
    Mike
    Tracksyde likes this.
