P3125
Discussion in 'Generation 1 Prius Discussion' started by Flagmichael, Jan 6, 2014.
  1. usnavystgc
    3,159
    990
    Tucson, AZ
    I vote for the canonical way lol.
  2. Flagmichael
    Flagmichael Junior Member
    2002 Prius
    I think I'll stick with the canonical method as well. I remember misgivings back in The Day about replacing MG2 because of the bearing preload issues, and seeing all the steps I am not interested in getting all that deep into it. A yard in Maricopa (less than 3 hours drive from here) lists a transmission for $550 and I would be able to do some impedance tests and smell the transmission fluid (I'll bring along the wife for that). The cost of the drive is probably about what I would pay for shipping the beast, too. The car will be worth about $3000 when it is back on the road, which doesn't leave me much room to get fancy. The local transmission shop quoted $1100 for the remove and reinstall... I'm wondering how much battle I am prepared for. I have to remember I'm not 60 any more.
  3. usnavystgc
    3,159
    990
    Tucson, AZ
    Def not a fun job. Good luck with it. Wish I could help ya
  4. Flagmichael
    2002 Prius
    Oh! You need driving directions....
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    lol, its a little far.
  6. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    I just bought one last week and had it shipped. Cost me 150 for shipping which was cheaper for me than driving there..I guess I am outvoted ,but I prefer to just replace the MG2 motor. Its a lot quicker and easier than replacing entire transmission. Also you do not need to drain the pesky invertor cooling system..I have done it quite a few times and it takes about a total of 4 hours to do a swap..
  7. Patrick Wong
    18,210
    6,513
    "I have done it quite a few times and it takes about a total of 4 hours to do a swap.."
    I'd be interested in seeing detailed photos explaining your procedure, next time you do this.
  8. Flagmichael
    2002 Prius
    I'm not committed yet.... What I saw in the link a few posts back indicated the real drag is shimming the new MG2. Otherwise I agree - if I don't have to drop the whole thing it will be a lot easier. How much is the MG2, and where do I look for one?
  9. ChapmanF
    18,542
    Right ... that's if you replace the whole MG2 (which you can't do without dropping the entire tranny anyway). The machining tolerances could be different so all of the bearing preload adjustment has to be done on reassembly.
    If you check Luscious Garage's site you can find a video on replacing only the MG2 stator. All the moving parts remain the original ones, the shims aren't disturbed, and it's all done through the end plate. Even though the stator isn't sold separately so you end up buying a whole MG2 to use one part from, what you save in labor....
    -Chap
    yotatoter likes this.
  10. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    You can buy a new one from Toyotapartsoverstock for around $979 plus shipping. Part# G110047040..
    usnavystgc likes this.
  11. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    You can also go used At car-part.com.. They will cost around 400 to 500 used.. But just beware .. these are used and may or may not be good...
  12. Markus Reynold
    Markus Reynold New Member
    Phoenix Arizona
    Hey all, I'm reviving this thread in hopes someone will chime in that has done the MG2 stator swap? Any tips or tricks? Otherwise it looks pretty straight forward.
  13. ChapmanF
    18,542
    Luscious Garage put up a video....
    WHCSC likes this.
  14. Trombone
    Trombone Active Member
    349
    122
    Allentown, Pennsylvania
    2002 Prius
    ...which is found where, please? Link appreciated.
  15. Josey
    Josey Active Member
    305
    117
    Virginia
    2003 Prius
    Not a terribly hard search
    WHCSC likes this.
