2010 to 2014 Prius, plug in or not
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Priusrage, Feb 8, 2014.
  1. Keep your current one silly!
    15 vote(s)
    35.7%
  2. Not worth it, just get the regular Prius!
    1 vote(s)
    2.4%
  3. Totally worth getting Prius plug in! Be perfect for you!
    26 vote(s)
    61.9%
  1. Priusrage
    Priusrage Junior Member
    Columbus
    I was thinking about trading in my current 2010 Prius for a 2014 with all the
    goodies, heated seats, solar roof and such. I live 10 miles one way from work.
    And the speed limit ranges from 25 to 45. I was thinking maybe getting the
    plug in would be beneficial since I'm not far from work. They would also allow
    me to plug in there 120v outlet if needed.
    Just thought I would post here since you guys have had yours for a while. I'm in
    Ohio, but don't mind traveling to go get a plug in.
    Thanks!
    Luke
    reason for trading is miles is getting high and I like to keep our family and daily driver
    current or under 200k miles. I'm not up that high yet. But Toyota is having 0% interest right
    now for 5 years which I'd like to take advantage of.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I'm 2.7 miles from work, one way. I fill up my tank once every six months. I use my Sony Rewards Visa card points to acquire a $25.00 BP gift card. So, essentially I pay nothing for gas. 10 miles one way, and a place to charge at work is a no brainer! go for it.!:cool:
    Priusrage, rogerv and Potorap like this.
  3. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    I voted "of course" but naturally that depends on price.
    If you can get it for $2,500 over the Prius3 sounds like your commute and charging capability will close that gap in a few years easy. Just did my taxes and the $2,500 tax back on the PiP was simple filing online
    Potorap likes this.
  4. Mike500
    Mike500 Senior Member
    2,593
    767
    I don't know how old you are, but think about your future.
    Save your money and invest it. If you're young and poor, you can work. The worst is being old and poor.
    In the EV mode, resistance heaters like those that heat the seats will quickly drain the battery and cause the ICE to kick in.
    Even if you're and experienced Master Electrician, like I am, it will still cost you in the purchase price of the charger and the electricity in charging.
    The "zero percent" loan is built in the higher price for the car.
    Potorap and markabele like this.
  5. retired4999
    2,652
    627
    Eau Claire, Wi.
    I agree with priuskitty.
    fits your commute really well! Go for it!
    Potorap and priuskitty like this.
  6. markabele
    5,084
    1,782
    Nebraska
    There are lots of needs and desires you have to weigh when considering this purchase. I would imagine one of those would be financial. From a purely financial perspective you should keep what you have. In almost all cases it's always the best option to just keep driving what you currently own. But as I said before, there are other factors to weigh. We are obviously all big fans of the PiP here, but that doesn't mean our advice one way or the other for this kind of decision is sound. Prioritize and weigh all the factors with your family and decide what's best for you guys. Good luck!
  7. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    Hey Luke,
    I started with trading in my 2010 advanced for the 2013 PIP. The reason for this was to take advantage of new battery technology and plug in option. As of right now I would recommend you wait for the 2015 4th generation to come out. Newer technology, extended EV miles and more options hopefully. The longer you wait the better it will get. 0% financing will be back. Just my thought. Take care and good luck.
    DadofHedgehog likes this.
  8. retired4999
    2,652
    627
    Eau Claire, Wi.
    Potorap, has a good point!
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Your commute is ideal for PiP. You won't save money but with the incentives help and a good opportunity to upgrade.
  10. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Not true. Maybe running both seat heaters on High would have an effect, but one seat heater on Low has a negligible effect on range. And Low is plenty warm enough.
  11. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Never trade a vehicle; it's a terrible financial move.
    Wait for the new generation of plug-in to come out, and then wait a year after that to make sure the bugs get worked out. Then buy the car with 0% financing and sell your 2010 Prius private party for a couple grand more than the stealership will offer.
    So, I'd wait at least 2 years, if not 3 to purchase. How many miles are on your car now?
    Epiphany2000 and markabele like this.
  12. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I've tried running both seat heaters to keep the EV batt from charging- they just don't draw enough current to put a dent in the PIP's larger battery.
    And even running the AC in the PIP for 25 min only drains maybe 1 mile EV range.
  13. markabele
    5,084
    1,782
    Nebraska
    The last statement is highly dependent on many variables. I think it would have to be pretty mild out to drain EV range at that rate.
  14. ny_rob
    1,968
    813
    L.I.- NY
    I'm sure if you couldn't swing it financially you wouldn't even be considering the upgrade. So if your good with the outlay- go for it!
    You have almost the perfect commute for the PIP. After the brutal months of Dec-Feb are over you'll probably be able to go to work and back home (assuming you'll recharge for 3hrs on 120vac at work) without ever running the engine. Even when you take longer trips- the PIP gets wonderful gas mileage. My commute is 28 mi each way- in the warmer months I can get up to 115 mpg on each leg.
    Outside temp at maybe 85-90 deg, AC set to 76 deg, fan set to speed I or II.
  15. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    2010 to 2014 within the same model generation is just not enough of a jump IMHO - PiP or not.
  16. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    "In the EV mode, resistance heaters like those that heat the seats will quickly drain the battery and cause the ICE to kick in."
    you must have a lemon !
    In a tough New England winter I've been using just the seat warmers (wifey's on high!) and I've seen no difference on my daily drives vs slightly warmer and no heated seats. No ICE kicking in either...
    re the original poster - he said he's got a lot of miles and wanted to keep his vehicles under 200k
    So he's replacing the car, its not a question of banking the $ instead and becoming a millionaire.
    He didn't say what his weekend routine was but based on his work route charging both ways it looks like he'd be putting at least 10,000EV miles on per year.
    Sure it'd be nice to wait til the next PiP with its 20mile? range but based on his work commute - he doesn't need that to go gas free now
  17. markabele
    5,084
    1,782
    Nebraska
    In the sun, no. In the shade, possibly.
  18. wjtracy
    wjtracy Senior Member
    11,364
    3,607
    Northern VA (NoVA)
    I was looking to see if you lived in CA and wanted to get one of the few remaining HOV green tags, then the answer would be easy...get the PiP and as soon as possible. In OH case it is trade-off of personal values...I tend to like the idea of waiting for the next gen PiP but I am not you.
  19. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    If you can get it for roughly the price of a regular 3, which many of us have, it's worth considering. Otherwise, while your commute is perfect for the PiP, it's also got to be pretty good in the regular model, so it won't pay back very well.
    That said driving electric is a benefit in and of itself that has some value, in my opinion.
  20. markabele
    5,084
    1,782
    Nebraska
    I know I've already said my opinion on here. But I feel people are only considering the new Gen3 versus a PiP. If that is really your two choices, then it is a no brainer to go with a PiP. But people need to be at least talking about/mentioning the keep your 2010 option.
    Priusrage likes this.
