EV question - uphill
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Pasaman, Feb 9, 2014.
  1. Pasaman
    Pasaman Active Member
    289
    115
    Southern California
    I was going up this huge hill today and had EV mode on and had 10 miles of EV. I noticed the EV kicked off and I assumed it was because of the hill. I kept the bar out of the power area. The car was warmed up already since EV was in prior to going up the hill
    2 questions - did the EV turn off because if the hill even though I didn't go into the power area? After the hill I went on a perfectly flat road and I could not get the EV to kick back in. I even wnment into the regen area and it still wouldn't. I toggled EV on off on and still nothing. It finally kicked in about five minutes later. What happened here?
    j12piprius likes this.
    51,585
    1) either the hill caused the battery to overheat, or you hit the powerline for a millisecond without realizing it.
    2) the ice had to warm up once it started, then you get ev back.
    CaliforniaBear likes this.
  3. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    Once HV kicks in, you have two choices.
    1) live with it until you reach 130°F, or;
    2) pull over, turn off the engine, then start up again in EV
    Hills play havoc with the EV system. Next time, before you hit the uphill, go into PWR mode and see if that helps. You should be able to move without pressing the pedal (and the EV motor) too far.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Depending on the battery SOC, temp and outside temp, you may not have full EV power.
    When outside temp was 20 deg F, I only had about 20 hp before ICE kicking in. The lower the SOC, the more power available. A full battery is less tolerable for high discharge.
    That's the nature of lithium battery.
  5. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    I don't believe the PWR mode does anything besides change the "law" of the accelerator pedal, making it ask for more power at smaller depressions. Does any one have any evidence that is does anything else? In other words, I don't think the PWR mode changes the relationship between the power meter and the motor torque.
  6. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    If your trip is going to require the ICE at sometime later you would be better off to go into HV for that hill and the warm up to 130 degrees. Save the EV miles for where they are more efficient. If its a short trip you will have to go a little slower up the hill to stay away from that milisecond of hitting the pwr area as described in another posting.
  7. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Yes. It is rarely a good idea to use EV on steep and/or long uphills. On downhills, however, switch to EV and let your range increase markedly.
  8. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    That doesn't sound right. Typical Lithium-ion batteries can discharge higher power output at a high SOC but can take back in a lower power level during regen. The opposite is true at low SOC where a relatively high amount of regen power can be absorbed but the output power capability is reduced.
    This is why the Tesla and LEAF etc. when near fully charged can run into regeneration limits when they are nearly fully charged even in pleasant temperatures. The Prius Plugin and other plugin hybrids like the Volt and etc. may face regen limits not primarily because of underlying battery limits but because their control software limits their SOC to be under 90% to enhance battery lifetime. The Prius may face these limitations more frequently because its smaller battery can reach its maximum SOC quicker during regen.
    This is also why quick DC charging a Tesla or LEAF slows down the power as the battery gets over 80% SOC although there is no power limitation when flooring the go pedal on a fully range charged Model S (or LEAF).
    The power output limitations you saw in the Prius Plugin on a fully charged battery were likely due only to cold temperatures.
  9. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Are you responding to me or to the original poster? It's true that a fully charged battery pack can't absorb more power.
  10. Pasaman
    289
    115
    Southern California
    Thanks all for the info. I never knew once the ICE turned on that the EV wouldn't go back on until the ICE was warmed up. Because of this my efficiency today was much improved!
  11. uropip
    uropip Member
    138
    S.E. MASS
    2013 Prius Plug-in
    Once its warmed up.. it will shut off quickly if that happens again.
    If u get the throttle bar into pwr section during ev driving it will trigger the ice.. so avoid that if possible.
    Galaxy Note 10.1 ? Pro
