2001 prius high voltage connector to traction battery called the cable to nowhere.
Discussion in 'Generation 1 Prius Discussion' started by royfrontenac, Feb 9, 2014.
  1. royfrontenac
    royfrontenac Active Member
    247
    100
    Kingston Ontario Canada
    2001 Prius
    For a 2001 prius there is a connector(female) orange that can be used to charge the HV traction battery
    Does anyone know where I can buy the matching connector (male).
  2. Mike500
    Mike500 Senior Member
    2,593
    767
    What does it look like? A photo would help.
  3. ChapmanF
    18,134
  4. royfrontenac
    247
    100
    2001 Prius
    Will take one, how do I send it - new to this process. Roy
  5. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
  6. ChapmanF
    18,134
    Unless I'm missing something, that photo shows the safety disconnect pretty clearly, but doesn't show the Plug To Nowhere at all. That's tucked around on the side.
    At any rate, I don't think the OP wanted to see the plug on the battery, but to find where to buy a plug of the other gender to connect to it. Last I knew, 3prongpaul had some of those to sell, as he mentioned in the post I linked above.
    -Chap
  7. royfrontenac
    247
    100
    2001 Prius
    Thanks for your help. I will contact 3prongpaul but i do not understand how to contact him from the post to link above ,what does that mean?
  8. royfrontenac
    247
    100
    2001 Prius
    Disregard about link, found it and contacted him. Thanks for the help. Roy
