Is 2012 PIP part of Feb 12, 2014 recall?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Marcus T, Feb 12, 2014.
  1. Marcus T
    Marcus T Junior Member
    86
    Northern NJ
    Just entered my 2012 PIP VIN on the Toyota "recall" site and comes up clean.
    Should I assume PIP isn't part of the 1.9 million recalled?
  2. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Mine came up clean too.. the recall mentions something about the motor generator ECU.. the PiP's MG ECU is most likely different, so maybe its not included in the recall?
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Yup, mine's clean too, knock on wood:cool:
  4. Marcus T
    86
    Northern NJ
    Hope so but hate to assume. Rav4 also had a recall today and my 2012 Rav shows it :( where PIP shows nothing :) .
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    PiP should be included. I have experienced the Fail-Safe mode a few days ago. I pulled over and rebooted and the car was fine.
    Edit: it turned out to be a different issue. See post #51.
  6. Marcus T
    86
    Northern NJ
    Then has anyone put their VIN in and seen the recall?
  7. Marcus T
    86
    Northern NJ
    Recall notice supposedly shows "certain transistors in the IPM could become damaged when operating the vehicle under high-load driving conditions, such as accelerating during highway driving. If this occurs, various warning lamps on the instrument panel will illuminate."
    Did this happen when you experienced your "Fail-Safe" mode and were you driving "under high-load conditions", whatever that means.
  8. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
  9. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Recall does not show up in my Toyota Owners site. It is not listed but it happened to me.
    The service center at the dealer I bought it from must be very busy. Service advisers forwarded my call to each other. The third one finally scheduled an appointment for this Sat.
    There is no loaner cars given! I'll have to rent a car for $35 a day!
  10. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Yuck!
  11. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Insurance might cover rental?
  12. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    What does fail safe mode look and feel like?
  13. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I think I was braking. I wouldn't say it was "high-load condition".
    Traction control, ABS and Brake (in red) lights came on. It drove funny and the brakes were weak with no regen.
    After the first reboot, the lights were still on, so I rebooted 2nd time and the lights went away. I then thought to see if there are any codes. Fired up Torque and checked. There were no Check Engine Light (CEL) code recorded. Perhaps, I should have checked while the lights were on.
  14. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    USB, I know you dont have a "cheap" OBD2 adapter, but what you described is what happened to me (esp the braking with no regen).
    I was also unable to pull any codes at all, which didnt make sense. However, after removing the OBD2 adapter, my problem went away and it has not come back. Also, my drive to work is anything BUT high-load. esp at the time the dash lit up like a Christmas tree.
  15. Pasaman
    Pasaman Active Member
    289
    115
    Southern California
    My 2014 PiP didn't come up under the recall.
  16. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I put in the VIN to my 2012 PIP: "There are no open Safety Recalls or Special Service Campaigns for your vehicle."
    Good news for me I guess...
  17. Marcus T
    86
    Northern NJ
    Then your problem doesn't seem to be the issue THIS recall is referring to. Maybe you have some other issue Toyota needs to address?
    We still need clarification as to whether or not today's recall impacts our PiP's or only regular Gen3 Prius's.
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I did not have my Kiwi plugged in when it happened. I plugged it in after the 2nd restart.
    So now, I wonder if yours was actually caused by the "cheap" OBD2 adapter.
  19. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Same with me I do have a cheap odb2 adapter and if I remove it no problems!
  20. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I don't know. I may be regening toward the limit. If I was, the boost convert may be at "high-load condition". I just don't know because I wasn't paying attention. You may be right, that my PiP has different issue. I'll let them check it out and update you guys.
