Is 2012 PIP part of Feb 12, 2014 recall?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Marcus T, Feb 12, 2014.
  1. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    The strange thing is not being able to pull any codes when it happened. Those codes should stay in the computer until manually cleared or reset.
  2. Marcus T
    Marcus T Junior Member
    86
    Northern NJ
    Thanks. In the meantime, this PDF from Toyota shows all the lights and warnings that would have come on for THIS recall. Does page 2 look like what you saw, if you remember any of it?
    https://techinfo.toyota.com/techInfoPortal/staticcontent/en/techinfo/html/prelogin/docs/cp/e0etofaq.pdf
  3. bisco
    51,585
    how many days did they say it will take to fix it?
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I took a pic. I have all the warning lights in that doc. I am not sure where the Check Hybrid System message is shown. If it is on the LCD screen, I did not take pic of it. I may have missed it.
  5. Marcus T
    86
    Northern NJ
    Yikes, then maybe PiP does need today's recall.
    No more racing my PiP on the interstate for the time being :LOL:
  6. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Here's what the Check Hybrid System message looks like
    If I recall, there was a long single tone beep and that message appears, then the other lights lit up for me. Later in the day, when this picture was taken, the other lights were gone, except for the CEL triangle and this message on the LCD. In my case though, after removing the ODB2 adapter, the message and lights all went away (and have not returned since).
    But hopefully your visit to the dealer will determine if something actually happened or not.
  7. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    You probably just hit one of those famous 8ft long X 6ft deep NYC pot holes!
    Nothing a good buffing-out won't fix :mad:
  8. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    About clearing codes...
    I had the orange! Master Warn. light and a different Check Hyb. Sys. msg. I was not sure how to clear codes (at that time) with my Torque App, so I plugged in a regular wired OBDII reader. It showed no codes! ??? I did the clear procedure anyway and the Orange Master Warn. light and my Check Hybr Sys. msg went away. That was weird. Since my wired OBDII did not report any codes, I wished I had used Torque in case IT would have. BUt from what I am hearing here, probably not either. I am confused about issues that turn on warning lights but do not register codes! :confused:
    Smart phone mounts | Page 3 | PriusChat
    "I had shifter (2) connectors disconnected when I turned on to ACC to verify my line of site that phone was just to the right of the "clock/time" on dash. When I was all done the orange ! triangle on left was on and there was a message to Check the Hybrid System." But it did not say 'stop vehicle...' ( I was in my garage ;) ).
  9. bisco
    51,585
    i got an email from my dealer today to bring her in for the recall.:(
  10. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    USB, See if anyone at your dealer can explain why/how getting warning lights can happen when no code show on OBDII readers. Ask them to tell you what codes they read with their diagnostic system.
  11. El Dobro
    El Dobro A Member
    7,079
    3,259
    Did you check your VIN on the Toyota website?
  12. bisco
    51,585
    no, the dealer included it in the email.
  13. El Dobro
    El Dobro A Member
    7,079
    3,259
    Interesting. I checked my VIN and there weren't any recalls listed.
  14. bisco
    51,585
    i just tried it, interestingly, the dealers vin was one more character then the website would accept.
  15. El Dobro
    El Dobro A Member
    7,079
    3,259
    17 characters, starting with J. What did the dealer add?
  16. bisco
    51,585
    18 characters, not sure which one is extra, i'll have to go look at the car.
  17. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    What did the dealer include in the email? Would you go to the link that we all have checked our VIN's against to see if yours shows up there? If it does not, then we know that website is not accurate.
    Thanks
  18. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    I be willing to bet the web site is either not correct or not up to date!
  19. bisco
    51,585
    dealer emailed me saying the last character is for thier use. i put the vin in again and it still says no open recalls. i'm waiting for the dealer to tell me if they have updated info or not.
  20. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    Bisco !
    fyi I'm in the Boston area and just called Bernardi Toyota - no recall on mine...
    Mine is a 2013 PiP but wondering if one of our dealers is wrong here
