Had to Reset my 2010 but disconnecting battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by osiris12, Feb 12, 2014.
  1. osiris12
    osiris12 Owner of 3, yes three priuses
    119
    Upstate NY
    My 2010 Prius is garage kept and I haven't taken it out in over a week due to the snow. I use my older Prius for that.
    Anyway, this morning was sunny but cold so i decided to take the 2010 for a spin to work. Well when I got in to the 2010, pressed the break pedal then start button, the dash came on but no Toyota welcome. And the car did not start. There was a yellow triangle on the upper dash to the right.
    Then I tried turning off the car, but it would not turn off either. I tried this cycle, for a while to no avail. So I decided that the battery must need a boost. But that too did nothing to change my situation.
    Finally i disconnected the positive contact on the battery and reconnected after about a minute. The car started without issue. I turned it on-off a few times and all seems fine. So I just took it to work.
    Has anyone experienced this before in a 2010 Prius? Or have any idea why the system needed a hard reboot???? (n)
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Check your 12V battery. There are multiple threads on this subject. Just do a search.
  3. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    If your 12 volt battery is the original (you did not mention), it could be on its last legs. Mine did the same thing you described and I wound up replacing it. 3 to 4 years is about the average life of them and they are not that difficult to change out. If after sitting a while again, your car has the same symptoms...change the 12 volt battery. New ones range in price around $200 +or- at O'Reillys or Autozone.
  4. osiris12
    119
    Upstate NY
    Thanks for the info. That would make sense since my battery is original. Is there a way to test it?
  5. techno-Zen
    techno-Zen Junior Member
    Mesa, Arizona
    My 2010 battery just crapped out after nearing 58k miles. I'm sure it's end of life for you as well.
    Just get a digital multimeter, or if you have a prius with a nav screen there is a way to check it there. I just can't remember what it was.
    osiris12 likes this.
  6. osiris12
    119
    Upstate NY
  7. phoenixgreg
    1,157
    291
    66
    Phoenix
    I think you want to enter "maintenance mode". Mine does not have OEM NAV so I'm not sure how to do it. Once you are in that mode, the 12 volt battery (if good) should show anywhere from 12 to 14 volts (engine running). But because yours is the original, it might be best just to change it rather than getting stuck somewhere. I think there are 4 nuts and bolts (10mm?) to remove - pull out the 90 degree vent plastic piece from the battery and swap it out.
  8. osiris12
    119
    Upstate NY
    I agree. no matter what, it is getting old. I have about 42k on the car. I thought the battery would last until at least 55k or so. My 2001 prius lasted 8 years until it started acting up.
    The battery is very easy to replace on all my Prius' (2001, 2006, 2010). Guess its time to go online shopping. Any suggestions for sites that have a good price for the Prius ICE battery?
  9. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    $173 includes free shipping: Optima DS46B24R Optima battery direct fit replacement for Prius 2004 + , Prius V & Plug-in Prius with Instructions
  10. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    The life of the battery in the Gen 3 seems to be even less than the Gen 2!
  11. BardManY2k
    BardManY2k Junior Member
    Michigan
    I just ordered/received mine. $147.05 free Prime shipping. Ordered Sunday night, arrived Wednesday. Arrived well packaged with 12.85V charge.
  12. osiris12
    119
    Upstate NY
    Thanks Guys. I went to amazon and it is $147.05 plus tax for a total $159.00
  13. macman408
    1,179
    367
    Several problems here...
    First, the battery will be over 12 volts any time in Ready mode, good or bad (or missing completely). Once the car is in Ready mode, the 12V system is powered by a DC-DC converter from the traction battery, which also charges the 12V battery. If the car thinks the battery needs charging, it will use a higher voltage. (So a higher voltage like 14V might actually mean your battery is *worse* than if it were ~13V.)
    Second, maintenance mode isn't a great time to measure the voltage of the battery, because you're putting a load on the battery. The usual recommendations of something like "<12.2V and your battery is less than half charged" or something like that no longer applies. (Toyota says that your battery is discharged if it is at 11.5-11.9V, as checked 20 minutes after turning the car and all lights off.)
    Third, it's not even accurate. I measured with maintenance mode and a multimeter simultaneously once - the Nav's maintenance mode said the battery was 11.5V, however my multimeter was reading 12.17V. That's so far off that it's just totally not useful at all for making a measurement on battery SoC; according to the manual, fully charged can be as low as 12.6V, while fully discharged can be as high as 11.9V. That's only a 0.7V spread, which is the same as the inaccuracy I measured on my car.
    Get a multimeter, visit an auto parts store for a free battery test, or just replace it because it seems like it needs it - but don't rely on the maintenance mode to tell you anything useful about the battery.
    cwerdna likes this.
  14. osiris12
    119
    Upstate NY
    Thanks for the info. I'm just going to replace it. I ordered it from Amazon and it should arrive today. $159 is not too bad
