What have you done to your c today?
Discussion in 'Prius c Accessories and Modifications' started by kingnba6, Nov 21, 2013.
  1. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    Engine Block Heater installed. Couldn't have been easier too! 14mm Gearwrench fits the transmission vent. Warm morning commute on this 8°F morning. Scangauge showed an 85°F engine coolant temp at startup in the morning.
    NDcowPoke likes this.
  2. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Where did you get that and how does it work exactly?
  3. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    I got it from the Priuschat shop. It's a Toyota Canada part. It's a 400W heating element. It slips into the pre-made hole in the engine block specifically designed for this. I left a review in the shop page too.
    How it works - Plug the car in two hours before you drive it. It raises the engine temperature so it warms up very quickly. It takes away a lot of the cold weather MPG hit. But the best part is that you get heat faster, and the windows clear of fog quickly.
    There's more posts about it around as the shop listing says there - search for EBH and get a lot of hits.
    This heater is why I joined the forum - the shop lead me here.
  4. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    very nice. after this winter in ny, im planning to get a block heater
  5. otbiker
    otbiker New Member
    25
    Installed the HC LED tail lights. Looks great and provides A LOT of light back there. As a "side note", the new LED vertical strips in tail light mode also show from the side of the car. I'll need to post a pic.
    cyeremian and koipond like this.
  6. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Ok problem. If I plug it in 2 hours before I leave I would have to get up at 6 am go out plug it in and wait. Or could I leave it plugged in all night? or no?
  7. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    I bought a Sunlite heavy duty appliance timer from Amazon to control my extension cord. I set it to turn on 2 hours before I generally leave. I have left it plugged in overnight a couple of times, and it seems to work fine - it's just a waste of 400w of power for those hours you don't need it.
  8. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Get a good quality timer and they will kill most of the power until that time that you set it to run.
  9. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    Today I installed the JDM Toyota OEM window visors. They certainly cost a lot more than other options - but they are far higher quality, and I prefer this style the most.
  10. kingnba6
    1,018
    242
    NY
    did nothing today but just took some pics.
    there are more in my C1 thread
    Blindhopes likes this.
  11. koipond
    koipond Member
    198
    40
    Please do post some photos. :)
    SCH-I535 ?
  12. garm
    garm mpg + cool = win
    215
    I installed Prius C visors as well. I have these in stock from Japan, I think they're as good as the OEM ones and quite a bit cheaper.
  13. kingnba6
    1,018
    242
    NY
    i finally cleaned the snow off the car since i havent moved it due to the snow. love having a suv as a second car
  14. thetakara
    thetakara Junior Member
    36
    ....why would you chance a ticket?
  15. los panda
    los panda Member
    155
    low risk.
    i had 4 officers from 3 different departments closely examine my car after i was the victim of a hit and run fender bender.
  16. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    i like to live dangerously, a 1/4 mile at a time.
  17. DawnM
    DawnM New Member
    Mississippi
    I love the front of your car! Where did u get that grill?
    w2kpugsly likes this.
  18. garm
    215
    Thank you! Here's what in front:
    Front Toyota garnish
    Front stainless trim strips
    Front Toyota sporty lip
    I should take a pic straight on from the front.
  19. DawnM
    DawnM New Member
    Mississippi
    I just totaled my 2012 c, prob next week I'm going to get the 2014 c habanero - I want mine to look exactly like yours! Send me a front pic when u get one pls:)
  20. navyjoe1987
    navyjoe1987 Junior Member
    25
    17
    I changed my cars theme, was orange and blue. Got new LED Taillights so I switched to black and red, happy with the results just need to figure out the hatch Toyota symbol. Want to do it as well. I also took off the hybrid badges and put on TRD ones. I like it, rims on Tuesday.
    PLSPUSH, B2FiNiTY and w2kpugsly like this.
