Cost of Electricity in New York State
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Electric Charge, Feb 13, 2014.
  1. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    In order to provide a clearer picture to New Yorkers about the cost of charging your car, I created a database/survey feature which is going to collect this info, and make it easy to search this data.
    If you live in NY State, please take a minute to add your data (only a few fields, registration isn't required).
    Electric Rates - ChargeNY
    If you see any problems or mistakes, please let me know.
  2. drash
    drash Senior Member
    2,599
    1,339
    Upstate NY
    XLE AWD-e
    This is the high value. Normally it's about 0.14/kWh and has been as low as 0.11/kWh.
    iPad ? HD
  3. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Hardly seems worth it at those prices. $0.11/KWH would be considered high over here. I wonder how low we could go if we had TOU pricing implemented. I've still got a dumb meter with the spinning wheel.
  4. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    The utility for Long Island (Nassau & Suffolk counties) is now PSEG Long Island, which is not on the list at the survey page. It replaced National Grid a few months ago.
  5. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Once again, many of us aren't primarily concerned with cost savings.
  6. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    not a lot of response on the file. have a few LEAFers in NY. interested in knowing their costs...
  7. Electric Charge
    545
    133
    Syracuse, NY
    Hmm, PSEG Long Island is what LIPA used to be, right? I pulled this list from the NY gov website, am surprised it has this kind of errors. I added PSEG to the list, thanks for letting me know.
    I only created the database yesterday, and haven't advertised it on any forums (am using the smart PriusChat folks for feedback before really launching it ;))
  8. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Thanks! The change from LIPA to PSEG was officially effective only on January 1st, although it was in the works since Hurricane Sandy.
    I entered my rate calculated from last month's bill, 22 cents per kWh.
  9. Electric Charge
    545
    133
    Syracuse, NY
    I'm assuming everyone is just combining the cost of supply + cost of delivery, right? Should I split the rate between delivery/cost, since you can shop for different suppliers? I just put it in the comments section for now.
  10. fuzzy1
    10,691
    Who is your provider? Have you looked at your cost recently?
    On PGE's website, I'm seeing rate components that add up to $0.10322 for the first block, then $0.11044 after that.
    Looks like PGE offers $0.07489 at the lowest, $0.16219 at the highest.
  11. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    oh ya!! ok, dont know what i "thought" i read earlier but was thinking this thread was 2 weeks old...
  12. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Just checked my bill and added mine. Just under .11 in Tompkins County.
  13. Redpoint5
    1,026
    509
    Portland, OR
    I'm just over the river in Vancouver, and use Clark Public Utility. The rate is $0.08041/KWH.
    My parents use PGE and their billing and rates are similar, unless something has changed in the last couple months.
  14. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    That bill of Redpoint's is a paragon of clarity. Good for them.
    Inexpensive electricity, too.
  15. fuzzy1
    10,691
  16. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    If you divide the total electric cost by the kWh used, the rate is .106, no? I assume the 'basic charge' is effectively the delivery charge that many of us see. Alone, my supply charge is only .054.
  17. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Our NYSEG bill is a marvel of complexity, but by dividing usage into total paid, I get 12.062 cents a KWH without the wind power subsidy, and 13.01 cents with.
  18. SageBrush
    11,627
    2,533
    Southwest Colorado
    If the goal is to know how much it costs to run an *EV, the fixed costs of the electricity bill should be excluded in calculating the cost/kWh.
    Rather than parse the bill, if the unit costs have remained constant and you do not have tiered pricing in the past two months some simple algebra would do the trick:
    Bill #1:
    Total cost = Fixed + kWh*kWh_rate
    Bill #2:
    Two equations, two unknowns.
  19. Air_Boss
    Air_Boss Senior Member
    4,248
    1,195
    New Yawk
    On Long Island (ex-LIPA-suction, now much the same with PSE&G) there are no fixed billing charges. Both energy cost and distribution charge are per kwh, and the recent total is near 22cts per.
  20. SageBrush
    11,627
    2,533
    Southwest Colorado
    That does not sound too complicated.
