  1. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Why did u go all the way to the battery in the hatch instead of the fuse box?
    VS980 4G ?
  2. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    There's a metal plate with the + terminal in the 2013 prius under the fuse box (other than screwing a screw in to it I don't think you can cleanly install it. Also if he uses the Tanabe STB like me the box is virtually impossible to get to in the front.
  3. CU2MIKE
    CU2MIKE Junior Member
    35
    32
    I wanted a clean, well hidden install. So we started the wire at the passenger side headlight, ran it through the opening near the steering wheel column, tucked the wires along the way and fished it through the hatch, took everything out of the hatch and tucked the wires and tapped the battery directly before putting everything back.
  4. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    Wow, you could have connected to the bolt in the engine fuse box, which comes from the 12v battery, and supplies positive to the entire box. Then sheathed your wire, all 1.5 to 2 feet of it. How is that not clean vs a longer run to the firewall? :confused:
    The bolt is seen here next to the screwdriver:
    SCH-I535
  5. CU2MIKE
    35
    32
    ^ read the quoted text
  6. JGI
    JGI Member
    77
    46
    Installed USB charging outlet behind the center armrest so my rear passengers can charge their phones/ipad
  7. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    That is a great idea. Well done.
    PlusIV
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I have an extra 12v cig plug that I was going to install in the same location.
    VS980 4G ?
  9. xliderider
    8,140
    3,278
    Honolulu, HI
    Have you tested it to see if the Apple products charge? Sometimes the Apple products need some wiring changes in the USB port to work properly. Refer to Gliderman's post #12:
    Add usb charging ports | PriusChat
  10. CU2MIKE
    35
    32
    Traded the Prii for something "slightly less" efficient...
    NAH just messing with you guys lol
  11. xliderider
    8,140
    3,278
    Honolulu, HI
    Lol, if that's your garage, Christmas is over. Someone needs to take down the lights. ;)
    SCH-I535
    ncmm87507 and ckam1989 like this.
  12. CU2MIKE
    35
    32
    Leave it to a Prii owner to ignore the Godzilla in the picture :p
    And it is my house, but I've been busy, so the lights stay until Christmas this year! :ROFLMAO:
    Merkey likes this.
  13. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    waiting for this projector type fog lights....
  14. xliderider
    8,140
    3,278
    Honolulu, HI
  15. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    I also can't read Japanese but here are some details that google translated...
    "Achieve the light distribution without unevenness
    and I realized light distribution without unevenness by adopting the projector (convex lens) to fog lamp.
    By the characteristics of the projector to minimize the diffuse reflection of light, it is possible to efficiently light up. Visibility is also greatly improved. Hi / Lo switch function and optical axis adjustment function deployment Hi / Lo switching function, because of the (adjustable with a screw in the side) optical axis adjustment function of vertical and depth direction can be changed to fit the body, also used to assist in the headlamp You can. Heat resistance and heat dissipation of the preeminent for the metal, fog lamp body is superior in heat resistance and heat dissipation. (You can also use halogen and HID) a very simple mounting performancewithout the need for processing, installation is possible with bolt ON Since you are using a bracket having the same shape as the fog lights genuine. ※ I can not attach it to the vehicle fog lamp does not stick to (including dealer or manufacturer option) original. Take part in dress-up lens shape of the projector fog brings a solid atmosphere, I will produce a front view of luxury car par. ■ Set contents lamp unit: left and right wiring two (valve is sold separately) H11: ※ socket shape model fit"
    xliderider likes this.
  16. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Will be interesting to see how this turns out.
  17. toyopri808
    toyopri808 Active Member
    226
    116
    installed coilovers!!! :)
    TRD springs + stock susp in the for sale section..
    Burna J likes this.
  18. xliderider
    8,140
    3,278
    Honolulu, HI
    You mean struts? ;) You have to be careful what you say when selling stuff on this site, and what pictures you post. Or someone will expect control arms, tie rods, etc will be included. :D
    SCH-I535
    Merkey, sarir97 and Jay J like this.
  19. toyopri808
    226
    116
  20. Lucky Lager
    Lucky Lager Junior Member
    87
    Installed LCD review mirror and a back up cam.
    Only part that sucked was feeding wiring and RCA from the hatch with oem wiring through the factory rubber conduit leading from hatch to the cars roof
