Transaxle Fluid Change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Austin Middleton, Sep 4, 2013.
  1. Mendel Leisk
    42,285
    One reason for the mystery regarding the transaxle fluid spec is Toyota's stand, that it NEVER needs changing. But yeah, stick with Toyota ATF-WS.
  2. Agape
    Agape Member
    378
    Ireland/Eire
    ATF for CVT's ?
    toyota seems to use Red fluid ATF WS into Prius cvt's. The part number for 08886-81210, the bottle does not say anywhere that it is for CVT's. However EVERYBODY uses it.
    for Vitz Toyota seem to use different fluid, it's called Super CVT:
    The Yellow fluid which is pictured below appear to be marked as specifically designed for CVT's (see print on the tin), the part number 08886-81205 - the note on the tin say's
  3. Agape
    Agape Member
    378
    Ireland/Eire
    this is what mechanic used in someone's Toyota VITZ (attached pict's)
  4. Agape
    Agape Member
    378
    Ireland/Eire
    This is what I got (attached picture):
  5. Agape
    Agape Member
    378
    Ireland/Eire
  6. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    I think the confusion comes from the Prius transmission being called a CVT witch it is not. It is an eCVT and uses entirely different mechanisms to achieve a similar result.
    The CVT using a purely mechanical solution.
    The Prius using an electrical solution.
    Both give thee effect of a continuously variable ratio that a CVT actually gives. The Prius eCVT only has one ratio but more than one drive input or output, enabling the apparent change in ratio.
    This is more a kin to slipping the clutch in a manual car pulling away in a high gear, but without the warring component or waste energy.
    John (Britprius)
  7. Patrick Wong
    18,210
    6,517
  8. Agape
    Agape Member
    378
    Ireland/Eire
    Conclusion: Red ATF WS will go to my prii.
    Ordered alu washer.
    Thanks everyone, Britprius, your sense is very correct. The terminology made me to think in such a way.
    Patrick and Mendel Leisk, thank you once again.
  9. Britprius
    5,194
    1,922
    If you have not already seen this have a look at the page below.
    Scroll to near the bottom of the page and move the slider buttons for MG2 or the ICE or both. The results are shown on the speedo and rev counters on the left. Hovering your mouse over the gear set will tell you what is connected to what. I think this shows just how brilliantly simple the Prius transmission is.
    Toyota Prius - Power Split Device
    John (Britprius)
  10. Tony D
    Tony D Active Member
    469
    132
    Dublin, Ireland
    The ATF WS is 100% correct as it was confirmed by techs in Toyota HQ in Belgium (couldnt get a definitive answer from Toyota Irl or UK as it doesnt need to be changed / lifetime blah blah blah)
    got mine done the week before last and it was a 5 minute job using a pump.
    The difference in the colour of the fluids was unbelievable especially as I have only 65k miles done. It was really due to be changed. If I have the car at 100k miles, I will do it again
    Britprius likes this.
  11. Britprius
    5,194
    1,922
    My transmission fluid was also dark in color and had an almost metallic sheen on the surface.
    John (Britprius)
