Speedometer adjustment?
Discussion in 'Gen 3 Prius Main Forum' started by RaZa, Feb 16, 2014.
  1. RaZa
    RaZa Member
    480
    93
    Is there anything a dealer can do to make the speedometer read the actual speed the car is traveling instead of the bs value that is always at least 2 mph higher than what I'm really going?
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Probably not.
    Read this;
    Speedometer - Wikipedia, the free encyclopedia
    There's bound to be a slight deviation in the accuracy of the speedo and if it read 1 mph over and you got a speeding ticket, you'd probably sue the manufacturer. As such, they put a little leeway into them to avoid this.
    You will probably find that your SatNav gives the correct speed.
    elementnomore likes this.
  3. bisco
    52,292
    is that why i'm getting such good mileage?:p
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Have you mounted a non oem recommended tire size? Using a smaller diameter tire would give you speedometer error as you are seeing.
    So, mounting a larger diameter tire will make your indicated speed decrease. ;)
    F8L likes this.
  5. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    With you anything is possible :whistle:
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    Nope. Going to a larger size tire will help fix the error but your displayed mpg will appear lower (more realistic). I think this is why Toyota put the 215/45/17 tire on the Five. It's shorter than the 195/65/15 and inflates mpg even higher. The 205/50/17 is closer to the OE 15" size but the mpg would drop even lower. Damn Toyota and their trickery! Hahaha
    xliderider likes this.
  7. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Get a Scangauge, it will show the actual mph.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Here's what I do....
    I simply look at the number my speedometer is reading and "subtract two".
    elementnomore and F8L like this.
  9. vskid3
    vskid3 Active Member
    773
    228
    I haven't tested it in my Prius, but even though my Civic's speedometer read a few high, the odometer was almost exact. The OBDII port gave the correct speed. The car knows what the speed is (if you have the stock tire size), it just lies to you on the speedometer.
    fuzzy1 likes this.
  10. bisco
    52,292
    no wonder i have blisters on my bumper.:cool:
  11. bisco
    52,292
    but whenever i go by a rader speed sign, i'm dead on.
  12. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
