5mm push on connector in an SAE world?
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Feb 19, 2014.
  1. bwilson4web
    16,201
    I'm trying to find 5mm connectors that look like these:
    In the SAE world, we can find 0.250 width connectors but I need a 5mm, 0.194-0.197" width connector. A cheap part, I'm not having any luck with my various Google searches nor the web sites of AutoZone, NAPA, and Granger. Looking for metric parts in Huntsville, AL, USA . . . well no luck, yet.
    As a workaround, I can take my Dremil tool and trim it down but this also wipes out the protective coating on the side I trim.
    Any suggestions?
    Thanks,
  2. Mike500
    Mike500 Senior Member
    2,593
    767
    The 5mm connector is a 3/16 inch connector in the SAE world.
    They are standard and widely available; just search 3/16 inch.
    They are commonly used in seal lead acid battery connectors. I have a good supply of them and any good electronics store will stock them.
    There is also an 1/8 inch connector that is commonly used in mini-low voltage dc motor leads.
  3. Mike500
    2,593
    767
  4. bwilson4web
    16,201
    Perfect! O'Reilly carries them!
