Reliable mpg and range figures for the Ford C Max Energi?
Discussion in 'Ford/Lincoln Hybrids and EVs' started by ny_rob, Feb 24, 2014.
  1. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    With all the early mpg/range BS from Ford that went on with it's initial release- where can we see real world reliable mpg and range figures for the C Max Energi?
    Thanks...
    Rob
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  3. bisco
    51,851
    the problem with plug ins is the variety of ev use.
  4. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    fuelly.com?
    Here's some for me.
    Most EV miles in a normal day (I could easily improve on this):
    My longest EV only trip on one charge:
    I bought it in November and have yet to purchase gas (2.5 gallons left on the dealers tank). Besides overnight, I charge 1 to 2 more times per day/evening @ L2 rates which usually covers the 40-60 miles I need to make between work and family needs. My EV range estimate is typically between 26-28 miles. I have around a 105 MPGe lifetime avg. @ approx. 4k miles. I'll need to fill up in March.
    YMMV
    F8L and gwmort like this.
  5. Trollbait
    12,507
    The rating was updated the 2014 model.
    Compare Side-by-Side
    45 city/40 highway/43 combine mpg for the hybrid. The Energi numbers haven't changed because it had to be tested itself due to differences in the drive train.
  6. ny_rob
    1,968
    813
    L.I.- NY
    Thanks for the response so far!
    Trying to decide if the C Max Energi is a good fit for my daily commute?
    28 miles each direction, about 20 miles of that is 60mph no stops.
    Free ChargePiont station at work.
  7. vskid3
    vskid3 Active Member
    773
    228
    Going off fotomoto's EV range, it looks like you would probably have to burn a little gas each way. It would do better than your PIP, but its up to you whether or not its worth it.
  8. gwmort
    gwmort Active Member
    985
    211
    Delaware
    Need to be careful with the screenshots of EV miles. I have noticed the car tracks miles traveled using regen while burning gas as "EV" miles, even though the source of those miles energy is gasoline and not the grid. I am getting between 18-20 miles from the grid charge on my way to work.
  9. mikefocke
    3,988
    1,801
    Sanford, NC
    Ford has issued another miscalculation apology/correction on their hybrids and plug-ins. Comes with a customer satisfaction rebate of up to 4 digits. While fuelly.com won't tell you what you are going to get, it is at least a real world average of what real people are getting. I find itreports within a rounding error of what I experience based on more than a year of use, a hard winter, varied use etc.
  10. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Today's new numbers are:
    C-MAX hybrid
    42 city/ 37 highway/ 40 combined
    100 MPGe EV combined
    C-MAX Energi
    40 city/ 36 highway/ 38 combined
    88 MPGe EV combined
    Chevy Volt (for comparison)
    35 city/ 40 highway/ 37 combined
    98 MPGe EV combined
  11. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    My parents regularly see 24-28 miles of EV range with no A/C or heat use, 23-25 miles with A/C and 12-15 miles in the winter with heat. They live in Minneapolis too with our brutal winters.
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Energi is a bigger heavier car. It makes more inline now.
    PiP efficiency continue to impress while being the most spacious PHV.
  13. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Not including Prius PHV in the comparison list was quite an omission, especially considering the venue... Here's how Toyota's offering stacks up with Ford's plug-in hybrids:
    C-MAX Energi & Fusion Energi
    88 MPGe EV combined
    Prius PHV
    51 city/ 49 highway/ 50 combined
    95 MPGe EV combined
    #13 john1701a, Jun 12, 2014
  14. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    True, but the Prius mpgs are so much better that it's not much of a comparison. There is Prius, and then there is everyone else.... :)
    usbseawolf2000 likes this.
  15. john1701a
    12,817
    5,303
    58
    Look at it this way... What comes next?
    The glory of bragging-rights is over. Reality is crashing down.
    Think about what Ford has to set for goals now.
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
  17. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    And the Prius is a tin can made out of cheap plastic with no sound deadening. It's not in the same class as the Ford Hybrids. The Prius is an appliance, to be used and thrown away. The Ford Hybrids are cars, to be enjoyed and savored.
  18. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    I can play that! Fords are junk. Toyotas last forever.
  19. F8L
    19,011
    4,083
    Grass Valley, CA.
    It's also the lowest in materials quality and driving enjoyment. Seems like there are always trade offs. :p
    hybridbear and jzchen like this.
  20. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Interior material quality is a downgrade from Gen2 but I like how Gen3 drives better. I think they focused on getting HSD to the mainstream and cheaped out on interior. For me, it is not a deal breaker as I am not a materialist (not implying anything) and I love/enjoy what it can do.
    I hope Gen4 would address both of those issues for you :).
    F8L likes this.
