Vent Blowing Cool Air at Higher Temps or Just Me?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by scoobydrew, Feb 16, 2014.
  1. scoobydrew
    scoobydrew Junior Member
    17
    SF Bay Area, CA
    Hi all,
    I purchased a brand new 2013 Prius 2 last October and I'm loving it so far.
    However, I notice that even if it's slightly warm outside, and I have my cabin temp set at a higher temperature than outside, the vent blows cooler air.
    For example, the other day it was 65F outside. Since it was warmer than usual, I turned down the cabin temperature to 65F as well. It was nice and cool, but a little TOO cold. So I turned it up to 70F. It was still blowing cold air. I had to turn it up to 72F before it was warm enough to feel comfortable.
    For reference, I had the fan speed at 1 and blowing at the windshield and feet.
    Is anyone else experiencing this?
  2. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Was the A/C engaged? If so, it will feel cooler than ambient air without it.
  3. scoobydrew
    17
    SF Bay Area, CA
    Thanks for the quick reply. A/C was definitely not engaged.
  4. fuzzy1
    10,602
    Air blowing at the windshield means the Defrost is on, which automatically engages the AC on most vehicles these days, including my Liftback. Try selecting some other vent combination, such as feet only.
  5. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    What he said.
    I don't think it is possible to have air blowing on the windshield without the AC running.
    Now.....the AC LIGHT probably won't be on but that is just a confusion factor.
  6. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    My 2010 blows cold/cool air out the center vents until I turn the temp to 75 or higher.
  7. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    The A/C runs when you push the defrost button, but you can direct the air onto the windshield using the air outlet switch without having the A/C come on. Also, 70 deg. air isn't going to seem very warm (this is a common complaint from heat-pump users). You need to use a thermometer in the air vent to really see what is going on.
  8. Easy Rider
    982
    210
    N. Central Florida
    I believe that is NOT true.
    The AC light does not come on but I think the compressor does run a little bit,
    to keep from accidentally suddenly fogging the windshield over.
  9. drysider
    823
    336
    Liberty Lake WA
    I am pretty sure this is not the case. The recirc/outside air will switch automatically to outside air in certain circumstances, but there is no mention of an A/C interconnect with the vent switch in the tech files. I will check it tomorrow to make sure.
  10. drysider
    823
    336
    Liberty Lake WA
  11. drysider
    823
    336
    Liberty Lake WA
    I am pretty sure that this is not the case. The recirc/outside air vent will switch to outside automatically in certain circumstances, but the tech files make no mention of an interconnect with the A/C. I will check tomorrow to see what is what.
  12. Easy Rider
    982
    210
    N. Central Florida
    Most cars work that way; that is, anytime defrost air is directed to the windshield, it is also cooled just a tad to decrease the humidity. Same reason that recirc is not allowed; to prevent a rise in humidity. I thought that was standard practice on ALL cars these days.
    P.S. Noted the 3 dupe posts. I find the "refresh" key useful to verify that a post you thought you sent really made it.
    That's F5 on a standard PC keyboard.
  13. drysider
    823
    336
    Liberty Lake WA
    I do not know what happened...too quick here to assume a problem, I guess. After doing some investigation, it appears that the A/C compressor does run when the vent switch is on the defrost setting. I watched the amp draw today while changing settings. The draw for defrost is the same when using either the vent or the defrost switches. I really do not like these hidden linkages. Why does the A/C light come on for the defrost switch but not for the vent switch? You can turn the A/C off in the defrost mode but not when using the vent switch defrost setting. I do not need the car to make these decisions for me.
  14. Easy Rider
    982
    210
    N. Central Florida
    Not most of the time maybe but you might be surprised at how FAST the windshield will fog over
    in the right conditions......and how long it takes to recover from that and get it clear again.
    That is especially true if the driver doesn't immediately realize what needs to be done.
    It is a safety feature. Whether or not you will need it.....ever......is just a wild guess.
  15. scoobydrew
    17
    SF Bay Area, CA
    Thanks for the replies everyone.
    Just to confirm what you guys are saying -- if I switch the vent direction setting to WINDSHIELD & FOOTWELL, it will automatically activate the A/C even though the A/C indicator light is not on?
    If I set the temp to 72 degrees at the above setting, it actually blows nice warm air. How does this explain the A/C situation?
  16. drysider
    823
    336
    Liberty Lake WA
    The A/C will cycle off and on while in the defrost vent setting....and the A/C light does not come on.
  17. Easy Rider
    982
    210
    N. Central Florida
    You are making this more difficult than it IS.
    The AC only runs enough to dehumidify. IF you are adding no heat at all, it will feel slightly cold.
    If you add just a tiny bit of heat, then it feels warm.
  18. wbray123
    wbray123 Junior Member
    71
    Colonial Heights, VA
    I've noticed in my 2013 IV that cool/cold air comes out of the vents with the climate control turned off. Is this normal? I turn it to my feet if it bothers me and I don't want the heat on.
  19. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Yes, it's normal. Air is directed to whatever was selected on the display. You can also select recirc and the flow should be greatly reduced with the system off.
  20. macman408
    1,179
    368
    Also, keep in mind that when you set the temperature, you're setting the desired cabin temperature, NOT the output air temperature. If you turn the temperature up from 65° to 70°, and the car thinks it's 75° inside, then it will still blow cold air. On the other hand, if you make the same temperature adjustment and the car thinks it's 66° inside, then it will start blowing warm air.
    So the easiest thing to do is set it to whatever temperature you are comfortable at, and just leave it there. (Obviously, this might vary sometimes based on what you're wearing, if the sun is shining, etc... But it'll at least be close.)
