Removing the seat covers
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jeffao, Mar 1, 2014.
  1. Jeffao
    Jeffao New Member
    I have an '06 prius that Im trying to install some used oem leather seat covers on the front seats, but I have no idea how to remove the two plastic pieces at the top that contain the holes the headrest slides into. Can these plastic bits be removed without breaking them? These are pretty much pinning the seat cover down to the top of the seat.
  2. woodnowin
    woodnowin Junior Member
    Suffolk, Virginia
    You have to release them from the inside after sliding the seat cover up or turning it inside out while still attached at the top. I forgot exactly how it releases. Most seats have a plastic tab to push in. Some are secured with screws.
  3. Bucky35
    Bucky35 Junior Member
    37
    NorCal
    You can also just stretch the seat cover over the plastic bits, that is what I did.
  4. Jeffao
    Jeffao New Member
    The leather is awfully tight though, and I don't want to damage it taking it off the old seat. Can those plastic bits come out somehow?
