Prius v: 300,000 miles club
Discussion in 'Prius v Main Forum' started by usbseawolf2000, Feb 7, 2014.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    Since some Prius v owners are approaching 300k miles, I am starting this thread to log ownership experience.
    1) Have you changed the HV traction battery?
    2) How about the 12v battery?
    3) Hybrid transaxle (transmission) fluid?
    4) How often do you change oil? What brand?
    5) How many sets of tires? Favorite brand/model?
    6) Changed brake pads?
    7) Lifetime MPG?
    8) Share anything else...
  2. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    2Fas4u sent me this. The first Prius v reaching 300k miles!
  3. 2 fas 4 u
    2 fas 4 u Active Member
    320
    351
    florida
    update: 310000
    OK here we go. Stopped at walmart to get a filter. And finally after years of not carrying royal purple, there I see not only 5w-20 but ow-20 I guess I had to buy 4 quarts at $7.65 each. Will keep u updated.
    ewxlt66 likes this.
  4. CanuckPT
    CanuckPT Junior Member
    34
    West Chesterfield, NH
    2014 Prius v wagon
    That's a lot of miles! Congrats! What year is your v?
    iPhone ?
  5. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    My guess would be a 2012.
  6. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
  7. 2 fas 4 u
    320
    351
    florida
    Update: 325000
    All is well other than a little oil burn. See u at 350
    ewxlt66, stephensprius and markabele like this.
  8. Estela13
    Estela13 Member
    Congrats!!!
    Would you mind telling me the tire that has given you the most out of mpg? thanks kindly..
    ~Estela
    CanuckPT likes this.
  9. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    2fas4u: has toyota reached out to you at all about sponsoring you in anyway? giving you a free car?
    are you going to try for a million miles?
  10. 2 fas 4 u
    320
    351
    florida
    Estela: the stock turanzas gave me the best mileage and lasted 165000 but they are expensive.
    Stephen: no one has called me and yes this will hopefully be my last prius.
  11. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    2fas - why will it be your last Prius? You planning on a different car or retirement? You've been an inspiration to many here, not only for your high mileage experience in Pri's, but the amount of seat/butt time in them!(y)
  12. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    I think Danny needs to give out an award to the highest mileage Priuses, since Toyota is not doing anything about it.
  13. 2 fas 4 u
    320
    351
    florida
    Although I love this car. Do the research brand new prius 6 yr payment plan 300000 in 2 years and then do a Kelley blue. We all make choices in life some good an some bad in my case as of now it's good who knows the future. However u can learn from my experience. Then add repairs such as battery engine transaxle an so on and so on. Even with a crash total I'm at a lost. Even a stolen vehicle I'm at a lost. Anyway my baby is treating me good even with a bent core in front of radiator from running over dead carcases in the night. And busted front bumper from fast running raccoon who tried to out run me. Anyway enough ranting for today. 330000
    ewxlt66, Estela13 and telmo744 like this.
  14. telmo744
    telmo744 HSD fanatic
    2,178
    768
    Portugal
    2 fas4 u. I would be great to see updated pic of odo on the panel, I usually link them to "hybrid deniers" to make a spark. :sneaky:
    ewxlt66 likes this.
  15. markabele
    5,084
    1,782
    Nebraska
    I guess I don't understand what you are saying. You would have just as bad depreciation in any other car you would have bought, probably worse. Am I wrong?
  16. jhinsc
    1,167
    259
    South Carolina
    It seems to me if you do 300k miles in 2 years, the income derived from those miles should be high enough to warrant a shorter loan period for payments. Stretching out payments for a depreciable asset, while using up most of it's usable life less than halfway through the payment period doesn't make any sense - but 2fas is already aware of that. But it seems to me a switch to any other vehicle (except diesels) will result in higher ongoing operating costs that will out weigh the benefit of lower initial cost of the vehicle. Diesels might be the way to go, except they have higher operating costs too; higher diesel fuel prices, higher maintenance costs, and higher initial cost to purchase. It's kind of a "damned if you do and damned if you don't" scenario.
    WesleyG94 likes this.
  17. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    @2fas4u is a champ!
  18. JeremyB
    JeremyB Junior Member
    24
    Huntsville, AL
    NADA takes a $6525 dollar bite with a 300,000 mile Prius v. CR-V is also $6525. Camry is $7500. Residual for Prius v, Camry, CR-V is pretty much the same. Over 330,000 miles, you'd save ~$8500 by using a Prius v vs a CR-V. Leaves a lot of room for a replacement battery back and transmission. Given the amount of driving you do, you're going to end up at a loss (before being offset with income earned by the miles driven) with any vehicle.
    jhinsc and CanuckPT like this.
  19. stephensprius
    670
    226
    Where are you at now 2fasfu?
  20. Troy Heagy
    Troy Heagy Member
    1,218
    Okay I have to know: Why do you drive almost 150,000 miles per year? That's over 500 miles each workday.
