Aftermarket Headlights?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by R1CH13, Mar 12, 2013.
  1. wotcher
    wotcher Member
    403
    97
    LA
    drunkin master - so your angel eyes and leds are hooked up as drl? do they light up with the headlights? if yes, then can you take a picture of them? in my project plans, I was planning on putting the halos behind the lip of the shroud. otherwise, i was told that the headlights would overshadow the angel eyes.
  2. drunkin master
    drunkin master Contributing Member
    394
    103
    92
    Los Angeles
    No I have it connected to my parking lights. I was planning on using them as DRL's but wanted my tails to be on as well. When my headlights are on you can barely see the halo since the HID's are brighter than them.
    It does overshadow them for sure.
    I will try to take some pics but later and post them.
  3. drunkin master
    394
    103
    92
    Los Angeles
    Here are a couple of daytime pics...
    Dylan Doxey likes this.
  4. xliderider
    xliderider Senior Member
    8,131
    3,269
    Honolulu, HI
    Thanks for the daytime pics. I know it's hard to capture what the lights truly look like in sunlight though. I suspect that the LEDs stand out more in actuality than they are showing up in the pictures.
    Still, the yellow halogens in the foglights are showing up very well compared to the LEDs.
  5. drunkin master
    394
    103
    92
    Los Angeles
    The fogs are hids but the leds are a bit dimmer in the daytime.
  6. swaggingprius
    swaggingprius Member
    88
    29
    East Coast
    Drunkin Master,
    Well, being in NY will make it a bit hard to take my car to your buddy's shop. Any chance the 5 LEDs used on each side available somewhere? I am considering doing a retrofit anyway, so drilling holes for this should not be that much more work.
    Thanks!
  7. dPruis
    dPruis Member
    47
    26
    Cerritos, CA
    Where could I get those headlights? Thanks
    sfv41901 likes this.
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    From Japan. They are from the Prius G which is only available in Japan
  9. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    What's the ball-park figure on how much your friend wants for this?
    About home much time does he need to work on it?
    I live in San Diego. I could make a day trip up to L.A. to get this done.
  10. MKART
    MKART Junior Member
    61
    Cincinnati, Ohio
    can those Prius G headlights be shipped? I'm totally digging that chrome side and what looks to be an LED eyelid in the bottom...:)
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Yes. I got mine from a seller on Japan yahoo auctions. After all was said & done, it was ~$1200 although that was 2 years ago.
  12. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    $1200...wow..do they make them with black housings and not all the chrome?
  13. Dylan Doxey
    1,389
    3,459
    92
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    the headlights have it standard chrome as well as black chrome.
    VS980 4G ?
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
  16. Accordlayingkit
    1,616
    1,747
    377
    gotcha... do u or anyone else on here have a primo set without any broken tabs they wanna Sell? (factory headlights that is)
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I have a set that I'm retroing. Once I'm done with them they will be listed for sale.
    iPad ?
  18. Accordlayingkit
    1,616
    1,747
    377
    retroing? how much u thinking?
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Bullet Salvador likes this.
